Edge cuts aren't square
« back to Joinery forum
Forum topic by roughcuts posted 02-08-2017 12:54 AM 770 views 0 times favorited 12 replies Add to Favorites Watch
View roughcuts's profile
roughcuts
18 posts in 593 days
02-08-2017 12:54 AM
Topic tags/keywords: jig question cherry joining
Hey guys. I am using 2” – 4” lumber for my dining tables. I have a Makita 16-5/16” Circular Saw. I built a jig using a straight edge on top of a piece of MDF. I square the edge off, and them put the two pieces i will be gluing together on the jig. I run the saw down the cut. The visible side of the joint meshes up perfect. However, one the bottom, there is a noticeable gap. Any ideas to get the joint seamless on top and bottom? Thanks
12 replies so far
woodbutcherbynight
5233 posts in 2461 days
#1 posted 02-08-2017 02:24 AM
Check your blade for being square to the base vertically. Sounds like the blade is slightly out at the bottom of your cuts.
roughcuts
#2 posted 02-08-2017 03:14 AM
I checked it with a square and it looked good. I confirmed it with a digital angle gauge and it was good. Im wondering if the board that wasn’t under the jig wasn’t sitting as flat as adjacent board?
View TheFridge's profile
TheFridge
9708 posts in 1538 days
#3 posted 02-08-2017 03:31 AM
Or your saw has a bunch of runout.
View gmc's profile (online now)
gmc
55 posts in 2208 days
#4 posted 02-08-2017 05:34 PM
my circular saw was off 5 degrees vertically that i could not correct. It must have gotten dropped and i either forgot or my son used it and didn’t tell me. This is the exact problem i found was boards wouldn’t be square to each other. Try a different saw even if you have to borrow one would be the quickest way to check. Good luck
-- Gary, Central Illinois
View LittleShaver's profile
LittleShaver
338 posts in 671 days
#5 posted 02-08-2017 07:34 PM
Did you try flipping one of the boards?
-- Sawdust Maker
roughcuts
#6 posted 02-08-2017 08:00 PM
I will give it a try and see if that works. The one thing i know for sure is that i have to use the short side of the saw base on the jig. The boards I’m using are 6” or less wide and the edge from the base plate to the blade is about 5.5”. when i clamp the jig to the board, it wants to roll. I will take pictures to give you a better idea of my setup. Hopefully you guys have some ideas as to how I can improve it.
roughcuts
#7 posted 02-09-2017 04:43 AM
I ended up building a carriage for the 16” Makita. There were too many variables using the previous method. Tested it and cut dead square. It wasn’t exactly level/cutting square, so i had to bevel the saw to compensate, checked it with my digital angle. Thanks for the input fellas
woodbutcherbynight
#8 posted 02-09-2017 05:26 AM
Practical solution, and it works. Nice.
View DirtyMike's profile
DirtyMike
637 posts in 954 days
#9 posted 02-09-2017 05:58 AM
No bevel on the saw horse legs?
View bigblockyeti's profile
bigblockyeti
5157 posts in 1772 days
#10 posted 02-09-2017 05:59 AM
Are you getting a glue line rip with the setup you have? I only ask because I have one of the Makita big boys too and I’ve only used it for cross cuts and maybe short (< 12”) rips on larger timbers. I wouldn’t have guessed it would be good for much more.
View jerryminer's profile
jerryminer
935 posts in 1493 days
#11 posted 02-09-2017 06:34 AM
I’m glad you were able to get good enough cuts. That saw is really a rough carpentry tool, not typical for furniture work.
When you get a jointer, you’ll never look back :)
View rwe2156's profile
rwe2156
2997 posts in 1532 days
#12 posted 02-09-2017 02:08 PM
Pretty difficult to build furniture with a skilsaw.
