How to mount inset drawers?
Forum topic by Claymation posted 09-16-2010 03:23 AM 9568 views 0 times favorited 6 replies Add to Favorites Watch
View Claymation's profile
Claymation
165 posts in 2692 days
09-16-2010 03:23 AM
Gang, I need a refresher course on how to hang the front of an undermount drawer slide to the inside of a cabinet. I am using inset drawers (see picture) so the slide can’t be mounted to the inside of the drawer opening, else it would be seen. The slide I’ve picked out doesn’t have a diagram for this type of application that I can tell… Am I barking up the wrong tree trying to use this slide? I was thinking about using the Knape and Vogt MuV undermount drawer slides for these cabinets. Has anyone here used them before? Are you happy with them? They look a little better than the Blum slides I’ve used in the past, but are more expensive. Do you have a recommendation on a slide similar to the KV MuV slide that is a little less pricey? I only need 3/4 slides for these cabinets, but it looks like the KV MuV only come in full extension models. If I go with the KV MuV slides I’ll need a supplier, too, if you know a good one.
Here’s a picture of my cabinet to help with the description I gave. The top 4 drawer faces and the side have been removed so you can see my question better. Since the drawer face is an inset drawer, I can’t attach the slide to the inside of the drawer opening on the face frame:
Appreciate any advice you have on this. Thanks!
-- Clay (Master Kindler) ~ Central VA
View randi's profile
randi
43 posts in 2696 days
#1 posted 10-12-2010 11:21 PM
http://www.knapeandvogt.com/where_to_buy.1.htm?chanel_id=11
A list of retailers at that link.
I would go with undermount in your case as well. Is this a kitchen or bath type cabinet? What is the intended purpose/weight range?
-- "A computer lets you make more mistakes faster than any invention in human history - with the possible exceptions of handguns and tequila." ~Mitch Ratcliffe
View Moron's profile
Moron
5032 posts in 3769 days
#2 posted 10-12-2010 11:49 PM
I always engineer the drawer “around” the drawer guide B4 I make the drawers. I wish I could help you.
View GaryL's profile
GaryL
1099 posts in 2707 days
#3 posted 10-13-2010 12:51 AM
Perhaps mount a backer block on the backside of your face frames so you can inset the drawer slides. Then your drawer faces will cover the end of the slides. This is assuming that you are not going with a hidden/bottom mount slide. I’m unfamiliar with the slides you have mentioned.
I also, like Moron, have my slides on hand first and then build the drawers to the slides specs.
-- Gary; Marysville, MI...Involve your children in your projects as much as possible, the return is priceless.
Claymation
#4 posted 10-13-2010 03:44 AM
Thanks for the comments, gang! I got it covered… see:
http://lumberjocks.com/projects/38426
GaryL
#5 posted 10-13-2010 01:11 PM
Clay..looks great, nice work..didn’t notice the 27 day “delay”. Need to keep an eye on that…duh.
Claymation
#6 posted 10-13-2010 02:33 PM
@ shopguryl and gary: Hey, that gets us all occasionally. thanks.
