sanding profiles help
Forum topic by siouxdawgs0409 posted 09-16-2010 02:15 AM 1246 views 0 times favorited 3 replies Add to Favorites Watch
View siouxdawgs0409's profile
siouxdawgs0409
107 posts in 3000 days
09-16-2010 02:15 AM
Hey there.
Is there any innovative ways to easily sand a profile with out losing the profile shape? I was wondering if anyone has made a negative of the profile out of balsa wood maybe? Where can you get blocks of balsa wood? Or any other ideas to sand the profile?
3 replies so far
View Gregn's profile
Gregn
1642 posts in 2890 days
#1 posted 09-16-2010 03:09 AM
Foam board works well for forming for sanding profile blocks. There is also a rubber profile set of sanding blocks you can purchase, they are wedged shape with the thick part having the radius edge for radius sanding.
16272 posts in 4125 days
#2 posted 09-16-2010 06:49 PM
I have a set of these from woodworker.com. If you are interested, the item # is 150-362.
TopamaxSurvivor
18195 posts in 3582 days
#3 posted 09-16-2010 09:37 PM
You can use epoxy to make a negative. Just cover the piece with kitchen wrap, get a piece somewhat shaped to the form yoiu need, fill it with epoxy and slap them together until the epoxy hardens,
