alcohol or water
Forum topic by daddydave posted 02-07-2017 05:29 PM 413 views 0 times favorited 4 replies Add to Favorites Watch
View daddydave's profile
daddydave
9 posts in 567 days
02-07-2017 05:29 PM
Looking into dyes for my fretwork scrolling. Seeing that dyes mix with either water or alcohol. Considering dipping piece into mixed dye and then wiping/blowing off excess.
What is recommended? Water or alcohol?
Also considering a 50/50 BLO-mineral spirit soak for finish (when dry) to a ‘satin’ look. Is this finish okay with the above mentioned dye process?
Thanks, Daddydave
View Les Casteel's profile
Les Casteel
160 posts in 3083 days
#1 posted 02-07-2017 05:37 PM
I believe in using alcohol as it raises grain far less than water and dries lightning fast. You can check out one of my demonstrations at my woodturning club www.woodturnersofswmo.org (Woodturners Of Southwest Missouri)
I havn’t tried the mineral soak so can’t speak to it. But, if it works (or not) please let us know.
Good Luck!
-- Les, Missouri, www.woodthatrocks.com
View mrbob's profile
mrbob
182 posts in 593 days
#2 posted 02-07-2017 05:43 PM
I prefer alcohol also for the same reason as stated, none or minimal grain raising. I also use that 50/50 mix to pop the grain or an oil based stain. You dye to get color, oil to pop the grain and give the wood some depth.
View Redoak49's profile
Redoak49
3283 posts in 2012 days
#3 posted 02-07-2017 06:32 PM
Plus one on alcohol.
View OSU55's profile (online now)
OSU55
1697 posts in 2013 days
#4 posted 02-07-2017 10:46 PM
Alcohol won’t raise the grain, but if you don’t add a binder, it will start wiping off when you wipe on the blo/ms mix. Couple of ways to go – 1) use a little shellac as a binder in the alcohol dye, or you can get oil soluable dye (I use WD Lockwood and naptha as solvent) and mix in a little blo or varnish for a binder. You might find this info useful.
