Finishing Panels
Forum topic by boatz posted 02-07-2017 04:37 PM 407 views 0 times favorited 5 replies Add to Favorites Watch
View boatz's profile
boatz
92 posts in 1795 days
02-07-2017 04:37 PM
This is a dry fit of a four drawer chest I am building. The side panels are ash plywood and the rest of the build is ash. The chest will be stained with gel stain and finished with Arm-R-Seal. I know I should stain the plywood panels before final assembly. Should I also apply the finish before assembly too?
-- You can't always get what you want. But if you try sometimes you just might find, you'll get what you need
5 replies so far
View pintodeluxe's profile
pintodeluxe
5757 posts in 2957 days
#1 posted 02-07-2017 04:41 PM
Looking good so far! You don’t need to stain plywood panels prior to assembly. That only applies to hardwood panels set into grooves. The plywood won’t expand or contract much at all.
Final assembly first, then finish the whole thing at once. I keep the back panel off casework, for better access while applying the finish.
View rwe2156's profile
rwe2156
3090 posts in 1625 days
#2 posted 02-07-2017 04:45 PM
It will make finishing a lot easier and a cleaner job. Do the rails and stiles, too.
Nice looking chest of drawers.
View OSU55's profile
OSU55
1861 posts in 2134 days
#3 posted 02-07-2017 05:08 PM
I see a possible mistake coming. Test your stain on the hardwood and the plywood pieces before touching the project. They typically absorb color differently, gel stain or not. You should test your entire finish schedule on samples before starting on the project.
boatz
#4 posted 02-07-2017 05:21 PM
- OSU55
Thanks for the tip. I had not tested the plywood
boatz
#5 posted 02-07-2017 05:23 PM
Looking good so far! You don t need to stain plywood panels prior to assembly. That only applies to hardwood panels set into grooves. The plywood won t expand or contract much at all.
- pintodeluxe
Thanks for reminding about the difference in plywood and hardwood panels
