I need some dust collector help.
Forum topic by awsum55 posted 02-07-2017 07:41 AM 558 views 0 times favorited 5 replies Add to Favorites Watch
View awsum55's profile
66 posts in 441 days
02-07-2017 07:41 AM
Topic tags/keywords: dust collector penn state ind canister filter
I have a Penn State Ind. DC-2 that I purchased in 1998 and I would like to replace my original bag with a canister type filter. My problem is I can’t find out anything about replacement bags for the the DC-2 unit. PSI doesn’t list that model or anything like it any longer.
Have any of you guys replaced a bag on one or know how I can get more information?
5 replies so far
4906 posts in 2426 days
#1 posted 02-07-2017 12:37 PM
What information are you seeking? I had a PSI DC-250 (predecessor to the DC2, I think) for many years. I replaced both bags when i broke that clear window on the lower bag while cleaning. The OEM bags were 5 micron, really inadequate for good filtration anyway, so I went to AFF had an upper oversized bag made that was less than 1 micron filtration. I then just put a plastic bag inside the lower one to catch the dust. But if i was doing it over I would go with a canister filter from Wynn industries, and still use the lower bag with a plastic liner. PSI’s DC business must have really went down the tubes in recent years, they have cut back on most all the stuff they sell.
View Carloz's profile
1147 posts in 524 days
#2 posted 02-07-2017 01:20 PM
Wynn says:
....If you have a single stage dust collector of ANY brand or size….
#3 posted 02-07-2017 04:16 PM
I was hoping to find a website that told me exactly what filter would fit this dust collector. I know I can take it all apart and measure, however that will make a huge mess and it will be easier if I could just find the specs. I’ve been reading about canisters and I noticed some guys went back to the bags because the canisters plugged up too easily. Now they make canisters with the flapper inside to knock off the fine dust. I also noticed I get a lot of leakage where the bags are attached to the middle ring, I have the metal bands with a spring on them for attaching the bags and they don’t seem to seal perfectly. I have to figure something out, there is just too much fine dust floating around.
View pintodeluxe's profile
5593 posts in 2746 days
#4 posted 02-07-2017 04:34 PM
I think you might have to pull it apart and call Oneida or Wynn. They are usually matched by diameter of the metal rim where the upper bag attaches.
It’s true, a single stage collector will clog quicker with a fine pleated filter. However if you clean it, it will work, and filter the fine dust. I have the PSI Tempest cyclone which has a huge pleated filter. The two stage filtration keeps the filter clean much longer. I like Penn State collectors, too bad they aren’t sold anymore.
A 2hp collector is big enough to handle a separator, which would help keep the filter clean.
#5 posted 02-07-2017 05:36 PM
Well, if you’re looking for a turn key conversion it may be a long search. Wynn is the place to start, but I’d bet you’ll be making some baffles or such to make everything fit. that’s just life with DC systems.
