Zero Clearance Insert Question
Forum topic by Seapep posted 02-06-2017 02:35 PM 334 views 0 times favorited 1 reply Add to Favorites Watch
View Seapep's profile
3 posts in 407 days
02-06-2017 02:35 PM
Hi folks,
First time posting here and fairly new to woodworking. My question is this I am hearing and reading a lot about zero clearance inserts for the table saw and was wondering if this could be done on mine. It is a 10” master craft saw (budget restrictions) but the insert I have is somewhat of a rectangle
Thanks for any help or guidance.
-- Sean Corbett
1 reply so far
View rwe2156's profile
2834 posts in 1411 days
#1 posted 02-06-2017 03:02 PM
You should be able to, in fact yours will be easier than most that have rounded ends.
You don’t want it to flex so make the insert at least 3/8” thick of solid wood. You can use the manufacturer’s insert with a pattern bit.
You may have to cut a few notches or rabbet the sides to fit.
An make at least a half dozen of them for angled cuts, dado’s etc.
