Need advice on new shop floor
Forum topic by Dan posted 977 days ago 770 views 0 times favorited 9 replies Add to Favorites Watch
View Dan's profile
Dan
3479 posts in 1046 days
977 days ago
Need some advice, suggestions and or ideas…
So I started setting up my first woodshop in Jan of this year. I have a detached two stall garage and I have been working hard all year getting everything done. Well after feeling the cool Michigan weather this morning it hit me that summer is over and I am running out of time to get my shop winter ready. I have two maybe two and a half months left before I will need to have my heating ready. I have everything taken care of but the floor. The garage is very settled which has created large cracks and dips in the garage. I got a few quotes earlier this summer to raise the floor and also to pour a new slab and with the amount that would cost me I would be better off just putting that into a pole building and starting from scratch. I don’t want to sink thousands into a the floor on a garage as old as this one is. My plan is to clean and fill the cracks as best as I can and then lay down a sub floor. I have seen photos of other garage shops where they put in a plywood sub floor but other then just seeing the pictures I would like some feedback on the idea, advice on it and or pointers. My shop floor is well settled and is no where near level so its a pain to get my stands and benches level. I am thinking a sub floor with stretchers and plywood will fix this problem. I am also hoping this will help with the heat.
It almost sounds a little too easy to just lay the stretchers down, throw down some plastic and then cover with plywood. Am I missing anything? Is there a better option for heat? Should I be worried about moister under the sub floor?
Ceiling height is not an issue if I am only raising a few inches or less.
Any advice,help,pointers would be great.
-- Dan - "Collector of Hand Planes"
9 replies so far
View rance's profile
rance
3855 posts in 1327 days
#1 posted 977 days ago
Just to stir the pot, there are other solutions…
www.kaswell.com/index.htm
or Google for Wood Block Flooring
View Dan's profile
Dan
#2 posted 977 days ago
Rance- Thanks, I will check the links. I am all ears on options.
Kick- I have the walls insulated or I should say I am working on it, about half done and will have the ceiling finished as well. That part I have figured out. Its the floor I am not sure on what my best option is with my budget. My budget is not cheap but I am not looking to put more then a grand into the floor at least not all before this winter.
I live just a little West of Grand Rapids. I am kind of in the middle of Grand Rapids and Holland.
View canadianchips's profile
canadianchips
1773 posts in 1163 days
#3 posted 977 days ago
I am estimating the size of your building to be 24ft x 30 ft.
I would pour a 3” concrete floor over what you have.
I would also consider putting floor heat in your shop.
Do the comparison cost of 3/4” treated plywood and stringers vs. concrete. You might be surprised !
View Dan's profile
Dan
#4 posted 977 days ago
I didn’t think I could pour a new floor over the top of the old floor. I was thinking a new floor needed to be so many inches in order to settle and or dry correct. I cant go too thick over the old floor.
Kick- Where are you located in MI?
View Lee Barker's profile
Lee Barker
1884 posts in 1016 days
#5 posted 977 days ago
There are some concrete products poured thin enough that they find level on their own. I would investigate that, given your situation.
Getting a flat wood floor over what you describe sounds really challenging to me, and to be safe, it needs to be dead level.
View Claymation's profile
Claymation
161 posts in 982 days
#6 posted 977 days ago
I’d pursue canadianchips’s suggestion. What a great opportunity to put in a heating system and fix the floor at the same time. You may find the cost delta with the sub-floor over sleepers very reasonable. Not sure of it’s application or even what type of ‘crete you would use but I don’t think it’s like what you use for a regular ‘crete slab; it’s thinner and self leveling. After it cures, maybe you could paint it with one of those epoxy paints… just a thought.
I bought a house that has a basement floor as you describe putting in, and I always wonder about mold under the plastic. Since I bought it, I’ve been thinking about the day I can tear it all out, level the floor properly and put down something else in prep of finishing the basement.
-- Clay (Master Kindler) ~ Central VA
View richgreer's profile
richgreer
4474 posts in 1241 days
#7 posted 977 days ago
It’s to know what’s best without seeing the garage/shop. However, laying stretchers down does not seem like a good idea to me.
Here’s an option that might work better. – - -
Bust through the concrete at a few locations, dig holes and install posts in the hole (either 4×4 or 6×6). Run a beam over the posts and secure. Then install floor joist and put the plywood on top of the joist. You would need something solid to attach the floor joist to on the walls.
You would probably dig a trench to keep the beam(s) low. Exactly how big the beams and joist need to be would depend on the span.
It’s a lot of work but in the end you should have a very solid and level floor. If I still lived in the Grand Rapids area I’d come over and help.
FYI – I’m one of the first to graduate for GVSU. When I went there it was GVSC.
View MarkwithaK's profile
MarkwithaK
264 posts in 1344 days
#8 posted 977 days ago
My house a slab floor and it gets rather cold in the winter around here (NW Indiana)....My solution was to lay PT 2X4’s down as sleepers on 2’ centers, fill the created cavities with 1.5” foam board….covered it with a vapor barrier and then 3/4” T&G plywood. It’s word out pretty well so far.
-- If at first you don't succeed then maybe skydiving isn't for you.
Claymation
#9 posted 977 days ago
MarkwithaK, do you have a walk out basement? If so, how’d you handle the transition at the door/slider? This is my problem. I’d leave the raised floor, except there is currently a “crazy” 4” step-down to a little patio area just in front of the door. Not a professional job, by any means.
