Epoxy question
Forum topic by woodenwarrior posted 02-05-2017 04:20 AM 517 views 0 times favorited 6 replies Add to Favorites Watch
View woodenwarrior's profile
woodenwarrior
238 posts in 2396 days
02-05-2017 04:20 AM
Topic tags/keywords: epoxy coloring transparency resource modern
I have four 10/4 thick live edge slabs that I’m looking to make into small tables with a river motif running through them in a channel down the center. I will be partially filling the channels with river stones and pea gravel and then filling the channel the rest of the way with a colored epoxy to give a water-like appearance. My question is this: What should I use to color the epoxy? I’m looking for just a pale blue color that maintains its transparent appearance. Any thoughts would be a big help.
-- Do or do not...there is no try - Master Yoda
View waho6o9's profile
waho6o9
8523 posts in 2779 days
#1 posted 02-05-2017 04:23 AM
woodenwarrior
#2 posted 02-05-2017 04:25 AM
I suppose I could experiment with that first.
View Monte Pittman's profile
Monte Pittman
30059 posts in 2540 days
#3 posted 02-05-2017 04:29 AM
Acrylic paint, aniline dye,
woodenwarrior
#4 posted 02-05-2017 04:31 AM
I’m thinking of using west systems. Will acrylic or aniline dye mix well with it?
View William Shelley's profile
William Shelley
595 posts in 1671 days
#5 posted 02-05-2017 04:33 AM
You want something that is miscible (dissolves in) with the epoxy. A water-based dye or pigment (like acrylic paint) might not work. However, since denatured alcohol is a thinner for epoxy, and it’s also a thinner for aniline dye, I would say that Monte’s suggestion of the aniline dye should work well.
-- Woodworking from an engineer's perspective
woodenwarrior
#6 posted 02-05-2017 04:36 AM
Both are solvent in alcohol. I have a lot of acrylic on hand (I paint also) I may give that a shot with some 5-min epoxy as a test. I appreciate the help!!
