How much difference is there between Dewalt 735 and 734 planers?
Forum topic by TopamaxSurvivor posted 09-14-2010 04:18 AM 19711 views 0 times favorited 24 replies Add to Favorites Watch
TopamaxSurvivor
18249 posts in 3645 days
09-14-2010 04:18 AM
Topic tags/keywords: dewalt 734 735 planer
edit: Preformance difference? snipe, ect?
24 replies so far
View SnowyRiver's profile
SnowyRiver
51457 posts in 3449 days
#1 posted 09-14-2010 04:42 AM
I believe the difference is the 735 has two speeds and the chip ejector. I think you get a better finish with the higher second speed. I think you could get snipe with either if they arent set up correctly.
-- Wayne - Plymouth MN
View ajosephg's profile
ajosephg
1880 posts in 3530 days
#2 posted 09-14-2010 04:47 AM
Probably biggest diff is 735 has 2 feed speeds.
I have the 735 model and the slow feed results in really smooth boards with little or no sanding required.
I don’t have any appreciable snipe, and since I have never used a 734 can’t say if it’s any better.
I really like the chip blower on the 735 – I use it with a Thien collector built into a 30 gallon garbage can. (You must connect it to some sort of a collection device or you will have chips in every nook and cranny in your shop.)
-- Joe
16274 posts in 4187 days
#3 posted 09-14-2010 04:48 AM
735-734=1
TopamaxSurvivor
#4 posted 09-14-2010 05:16 AM
I stopped by HD to look at there display models, again. I raised them up to where I could see underneath. The feed rollers on the 735 are an inch further from the cutter head than the 734. At 2.5” vs.. 3.5, I wondered if that will make any difference on how stable the wood it coming through? Is that where you got your “1” Charlie? :-))
thx ajoseph, that is good to know:-))
SnowyRiver, there does’t seem to be much to set up as far as the tables go. 735 has one big one. 734 has a couple that fold down. Seems like the 735 would be better, just wonderinig if it is $300 better:-))
View derosa's profile
derosa
1572 posts in 2804 days
#5 posted 09-14-2010 05:33 AM
One of the magazines compared them a few months ago and did note that with the tables the 735 had less snipe and either the least or second least amount of any of the benchtop versions tested. Biggest differences are the width and cutting speed. After market blades are also available for the 735 but not the 734 that I’ve discovered yet. That said, although I have no point of comparisonn, my 734 has been a pleasure to use and works well.
-- --Rev. Russ in NY-- A posse ad esse
View ND2ELK's profile
ND2ELK
13495 posts in 3743 days
#6 posted 09-14-2010 05:51 AM
When I worked at Lowes part time, I sold 2-735 to 1-734. Most people felt the 735 was the better machine.
-- Mc Bridge Cabinets, Iowa
TopamaxSurvivor
#7 posted 09-14-2010 06:03 AM
Thanks guys,
Kkickback, do you use in & out feed tables in addition to the one on the machine?
View PurpLev's profile
PurpLev
8534 posts in 3617 days
#8 posted 09-14-2010 06:05 AM
as mentioned:
735 has the following over the 734:
1. auto cutterhead lock
2. 2 speeds
3. thickness stops (allows you to repeatedly get back to common thicknesses for consistent material thicknesses)
4. chip ejector
5. a more robust build
Both planers have gotten good reviews, and both will thickness wood very well.
I personally have the 735, figured might as well get it all. so far it’s a work horse, and does not miss a beat.
TopamaxSurvivor
#9 posted 09-14-2010 06:56 AM
Thx kkickback; Sounds like it works very well the way it arrives ;-))
Purp, I am leaning towards going first class with the 735 too; even though, either sounds like a winner.
View TLE's profile
TLE
25 posts in 3417 days
#10 posted 09-14-2010 08:07 AM
I have a 735. I like the through speed of the faster setting for general dimensioning. I have the accessory fold-down tables. I guess they are worth the money if you keep them well leveled (they have screw-thread leveling). You could achieve the same or even better control with a shop made setup – but roll-away, compact storage is an issue in my shoebox sized shop. Giving the board just a little help by hand, holding the ends up and level going in and out seems to be all I need to virtually eliminate snipe.
The elevation mechanism on the 735 is accurate and positive enough that I can measure the stock that I am machining with my caliper for the last pass and dial in the cut on my dial indicator – it will get me thickness consistency to within a thousanth or two. While this could be seen as just a little anal, I do like being able to precisely recreate a crucial piece of my project that I have just butchered.
Tim
View studie's profile
studie
618 posts in 3115 days
#11 posted 09-14-2010 08:25 AM
I like my 735, it has 3 blades on the cutter head (reversible) and the chip extraction is exceptional with a DC. I got the extension tables for $60 and seems better but still some snipe. It has gone through IPE with no fuss as well as other hardwoods just fine. One time I had a problem with feeding some Douglas Fir thru and I gave it new blades as well as a cleaning of the rollers & the table surfaces then worked just fine. I think a good cleaning will help these planers what with the sap issues slowing it down from time to time. The 2 speeds are a good thing too, 4 post screws even better. I love it.
-- $tudie
View Cato's profile
Cato
701 posts in 3281 days
#12 posted 09-14-2010 12:58 PM
Topomax- another 735 fan here as well. I have the outfeed tables and the rolling cart, so that I can wheel it around.
The outfeed tables I adjusted the outer edges slightly higher than the bed and I don’t get any snipe. Got those and the cart from Griz catalog. best price I could find on them.
This is a workhorse machine and is very robustly constructed. I am really impressed with it.
View Brian024's profile
Brian024
358 posts in 3369 days
#13 posted 09-14-2010 05:01 PM
Anoter vote for the 735, the 2 speeds are great. Definitely get the extension tables, they help a lot with snipe. I still have snipe but when running boards over 8ft long or small pieces shorter than 10”.
View rbterhune's profile
rbterhune
176 posts in 3190 days
#14 posted 09-14-2010 05:28 PM
I have the 734 and am very pleased with it. PurpLev did a good job of highlighting the differences. He is also right that both machines have received good reviews. I think it comes down to how often you’ll use the machine. I’m not a professional or even a serious amateur and I work wood when funds permit me to do so, so I couldn’t justify the higher cost. If I were one of these guys who uses their machine very regularly I would say the higher cost is easily justified. I think both thickness the wood well but the convenience of an automatic locking head and chip ejector would be nice.
View CiscoKid's profile
CiscoKid
343 posts in 2842 days
#15 posted 09-14-2010 08:14 PM
I wore out a 734 (I do a lot of resawing and surfacing) and replaced it with another 734. A buddy of mine has a 735 and, while that slower speed may be nice, mine can put almost as good a finish on hard wood as his with sharp blades. I just could not justify the cost difference between the two machines and used the money saved to buy a hollow chisel mortiser that caught my fancy. If the 734 were 13” and not 12-1/2” I would consider it almost perfect.
-- Al, Culpeper VA
