Head hurting on this router decision question...
Forum topic by newbiewoodworker posted 09-14-2010 02:27 AM 895 views 0 times favorited 7 replies Add to Favorites Watch
View newbiewoodworker's profile
newbiewoodworker
668 posts in 2827 days
09-14-2010 02:27 AM
I figure for my next project, I will build a router table. Then I can redo the edges on the table, when I repair it… :)
Now my question is: How is the HF 1.25hp Plunge router? Ryobi Fixed Base?
Is a .25 Collet okay? Since it seems all the low end ones have that number…
Thanks.
(Dang.. woodworking gets expensive…)
-- "Ah, So your not really a newbie, but a I betterbie."
7 replies so far
View AaronK's profile
AaronK
1506 posts in 3464 days
#1 posted 09-14-2010 02:37 AM
i’m not sure about the specific models, but generally the lower end tools tend to not work so well – you get things like sloppy plunge mechanisms as well as a lot of runout in the arbor.
that said, if all you are using a router for is basic edge treatment, you might be ok. Also check local want ads for used higher-quality tools.
the collet size basically affects stability, as I understand it. a 1/4” collet will be find for smaller or light-duty jobs, but it can begin to get wobbly when you try to take off too much material too quickly.
View jusfine's profile
jusfine
2422 posts in 2925 days
#2 posted 09-14-2010 02:40 AM
Many of us started out with a 1/4” collet, but most routers now come with both 1/4 and 1/2” collets.
I have a number of routers, mostly Porter Cable, 1 Makita and 1 Festool.
I would think you should buy one that has the flexibilty to accept 1/2” bits, unless you first purchase a trim router to get started.
Have not personally bought anything from HF.
-- Randy "You are judged as much by the questions you ask as the answers you give..."
AaronK
#3 posted 09-14-2010 02:40 AM
my first router was an old Skil model, and I still use from time to time. I got it for $25 at a pawn shop. the good thing about used tools is that if I ever want to resell it again, i’ll probably be able to get my money back. just food for thought :-)
View twiceisnice's profile
twiceisnice
95 posts in 2826 days
#4 posted 09-14-2010 02:49 AM
What do you plan on doing with this router and how much money are you willing to spend?
View Sawdust4Blood's profile
Sawdust4Blood
404 posts in 3021 days
#5 posted 09-14-2010 02:49 AM
I wouldn’t recommend going any smaller than a 2 1/4 hp router (larger if you can) for use in a router table. I don’t think a 1 1/4 will allow you to use larger profile bits unless you have the infinite patience necessary to nibble away the profile in a zillion small passes. The advantage to a 1/2 collet is that there will be less bit deflection and wobble (particularly in more aggressive cuts) with the stiffer 1/2” shafts. For the most part, I only use 1/4” shaft bits in my Bosch Colt palm router.
for overall best value, there are several models of router kits that come with a 2 1/4 hp motor and both plunge and fixed bases. This is one of those areas where spending a little more up front will save you a lot of money and frustration in the future.
-- Greg, Severn MD
View ajosephg's profile
ajosephg
1880 posts in 3561 days
#6 posted 09-14-2010 03:11 AM
Due to the thickness of the router table many (most?) bits with 1/4 inch shanks may not be long enough to do the work, to say nothing about the safety factor. So I’d say you most definately need a 1/2 inch router.
Let me clarify: To get the bit height where it needs to be for many operations, I found that a bit extender is required, and they will only fit a router with a 1/2 inch drive.
-- Joe
newbiewoodworker
#7 posted 09-14-2010 03:25 AM
I may hold off on this I decided… I just came to the realization that its only going to get colder.. :( So I think first on my list is to pickup a space heater… since its cold in an uninsulted garage…
Then I may do a planer table… since I just bought a planer, so I guess I dont need another tool yet…. atleast for a week or so…
Thanks though folks..
