How to mix Stain for a Contemporary Beige / Gray Color - Oak kitchen Table and Chairs.
Forum topic by Prizen posted 02-03-2017 06:44 PM 587 views 0 times favorited 4 replies Add to Favorites Watch
View Prizen's profile
Prizen
31 posts in 2094 days
02-03-2017 06:44 PM
Hi all
I am refinishing an old oak kitchen table and chairs. Currently, I am sanding off the old finish with 120 grit and will then do another sand with 180.
I will to stain the table to get a gray / brown color, similar to the below floor color. However, I have not seen any off the shelf stock stains that get to this color, so I figured that I might try to mix it up myself. Has anybody any idea on how I might start this process, or any clue on what colors I may need?
I have access to the traditional dark oak / mid oak/ Mahogany / Rosewood / Walnut stains, but not sure how to get from them, to my chosen color?
Question 2 is on the top coat – I will probably need a polyeurthane varnish I guess, as this will be a kitchen table and so subject to the usual stresses strains and stains!!!
Thanks!
View Ripper70's profile
Ripper70
1149 posts in 1082 days
#1 posted 02-03-2017 06:57 PM
Minwax makes a Classic Grey tint that might work.
-- "You know, I'm such a great driver, it's incomprehensible that they took my license away." --Vince Ricardo
Prizen
#2 posted 02-03-2017 07:36 PM
Thanks Ripper but I’m afraid that brand can’t be sourced in my country, Ireland. I can get Mylands only
View EngineerChic's profile
EngineerChic
34 posts in 678 days
#3 posted 02-04-2017 12:27 AM
What wood species are you working with? Iron acetate (steel wool in white vinegar) can be diluted to get a grayish tone. If it’s too strong it can turn some woods dark gray/ almost blackish-blue. You might be able to layer a thin grey color under a warmer brown stain to get the look you are after.
View Mark Kornell's profile
Mark Kornell
1169 posts in 2705 days
#4 posted 02-04-2017 12:57 AM
I’ll suggest an aniline dye. I’m partial to W.D. Lockwood (http://www.wdlockwood.com/), but there are other suppliers. From Lockwood you’d have to do mail order, but you only need a 1 or 2 oz (50 g) so it isn’t expensive to send.
It is a power you mix into water, alcohol or oil, depending on what you order. Easy to use, just wear disposable gloves.
They have a number of grey tones, ranging from blueish to brownish. I did a project using one of their dyes on maple and it worked very well. Project is here:
Click for details
I used their water-soluble #163 Weathered Oak. On maple, it is less brown than what you are looking for, but on oak, might be just right. Order 3 or 4 different greys and make some test boards.
-- Mark Kornell, Kornell Wood Design
