Need some advice
Forum topic by Fireguy82 posted 02-03-2017 02:27 AM 519 views 0 times favorited 7 replies Add to Favorites Watch
View Fireguy82's profile
Fireguy82
4 posts in 573 days
02-03-2017 02:27 AM
Topic tags/keywords: question walnut leppard wood lacewood finishing
I am working on a wood cover for our stove. It has alternating strips of 3in wide walnut and 1in wide leppard wood. There is also a 7×7 square of walnut crotch in the center.
How would you finish it? I’ve thought about just using General Finish Salad Bowl finish. Being pretty new to woodworking, I’m not really sure how to really bring the grain of both woods out.
Thank in advance.
7 replies so far
View LittleShaver's profile
LittleShaver
346 posts in 703 days
#1 posted 02-03-2017 05:10 PM
I use a blend of mineral spirits and bees wax for anything in the kitchen. Heat 3 parts mineral oil in a double boiler to about 140 degrees, stir in 1 part bees wax until melted. Pour into a container (wide mouth). Once the mix cools, wipe on, allow to soak in for an hour or so, then wipe off the excess.
It’s food safe and easily renewable. My wife uses it on her cutting board and renews every couple of months.
-- Sawdust Maker
View Snowbeast's profile
Snowbeast
84 posts in 1421 days
#2 posted 02-03-2017 09:49 PM
Just make sure you use MINERAL OIL and not mineral spirits or heating this mix on the stove will result in a need for rebuilding your entire house!
View mrbob's profile
mrbob
182 posts in 652 days
#3 posted 02-03-2017 10:47 PM
An other oldie but goldie is 1 part Bees wax, 1 part boiled linseed oil and 1 part mineral spirits , warm up mix, let cool to solidify, I would think you could use mineral oil instead of the MS, just never tried that.
mrbob
#4 posted 02-03-2017 11:11 PM
Just curious, why do you want to cover your stove?
Fireguy82
4 posts in 573 days
#5 posted 02-04-2017 01:27 AM
My wife wants more counter space and the burners hidden
View OSU55's profile
OSU55
1787 posts in 2073 days
#6 posted 02-04-2017 05:11 AM
Minwax poly – foodsafe, much more abrasion resistant, no cooking it. Mix 1:1 with ms and just wipe. Mix in some wd lockwood oil based dye if a little color is needed.
LittleShaver
#7 posted 02-04-2017 05:22 PM
It s food safe and easily renewable. My wife uses it on her cutting board and renews every couple of months.
- Dan Hulbert
ARRRRG, As corrected by someone else, I should have listed Mineral Oil rather than mineral spirits. Must have been some kind of senior moment.
-- Sawdust Maker
