Grizzly G0771 table saw and Vega fence system
Forum topic by chef57 posted 02-02-2017 06:47 PM 980 views 0 times favorited 6 replies Add to Favorites Watch
View chef57's profile
chef57
17 posts in 500 days
02-02-2017 06:47 PM
Topic tags/keywords: grizzly g0771 vega fence question
I am considering purchasing the Vega fence system for my table saw. I was wondering if anyone can tell me where I will mount the power switch or what I have to do to mount the switch.
The power switch is currently mounted to the underside of the factory front fence rail. Looking at the Vega fence rail, it seems to be a round bar and from what few pictures of saws with the Vega fence the power switch seems to be mounted to the underside of the cast iron wing.
Does the Vega fence account for “fence mounted power switches”?
View Dustin's profile
Dustin
529 posts in 762 days
#1 posted 02-02-2017 07:21 PM
Chef,
I can’t offer much on the Vega, but as far as after market fences go, I had the Accusquare on an old craftsman contractors saw, and it worked great. It may be worth considering as this is a square style rail, and may solve some of your problems.
-- "Ladies, if your husband says he'll get to it, he'll get to it. No need to remind him about it every 6 months."
View kcfandjc's profile
kcfandjc
7 posts in 1649 days
#2 posted 02-02-2017 10:27 PM
I put the Vega fence on my Grizzly G0715, which also had the rail mounted switch. I just cut a piece of angle iron to use as a mounting bracket and drilled a couple holes. I’ll try to remember to take a picture later tonight and post it here.
View Kurt T. Kneller's profile
Kurt T. Kneller
126 posts in 1385 days
#3 posted 02-02-2017 10:59 PM
I mounted a vega pro 50 on my older rigid and love it. I ended up attaching a section of incra t-track under the rail to mount my switch.
-- Start with ten, end with ten.......
chef57
#4 posted 02-03-2017 08:52 PM
Thank you all so much, it never occured to me to use an angle brackett or t-slot both great ideas. Again thank you.
kcfandjc
#5 posted 02-03-2017 11:36 PM
Here is the picture of mine. I’m pretty sure one of the holes in the extension wing was already there so I just had to drill one more. I painted the angle iron and bolts black so that it matched better.
(not sure why the picture is showing up sideways)
chef57
#6 posted 02-07-2017 11:49 PM
Thank you for the information, I ended up using a piece of angle iron and mounting the switch to the underside of the table using the fence rail bolts. Works great.
