How to make large spoons
Forum topic by PBthecat posted 09-13-2010 03:36 PM 1577 views 0 times favorited 7 replies Add to Favorites Watch
View PBthecat's profile
PBthecat
53 posts in 3172 days
09-13-2010 03:36 PM
My son recently had a go at making curly maple mixing paddles for use in the kitchen. He used a combination of my bandsaw, a balloon sander and scotchbrite. They came out looking very good and now he’d like to try some large spoons ( 15” long) and needs a largely machine based method to form the bowls of the spoon. I’d like to know if anyone has a suggestion on how this can be done.
Thanks
-- "Every hundred years, all new people"
7 replies so far
View uffitze's profile
uffitze
199 posts in 3076 days
#1 posted 09-13-2010 04:04 PM
why does it have to be machine based? a gouge or two will easily do the job.
if you must use power tools, a power carver or an angle grinder outfitted with one of the carving blades is what you are looking for.
View richgreer's profile
richgreer
4541 posts in 3196 days
#2 posted 09-13-2010 04:28 PM
I have a friend who makes a lot of spoons. Making spoons is “his thing”.
On smaller spoons he uses nothing more than a sanding device like a balloon sander. On larger spoons he often uses a ball like rasp on the end of a drill. He also uses chisels to start on the bigger spoons.
As an FYI, he cuts out most of the spoons with a bandsaw and often uses a router to round the edges. He also turns some of his handles. The turned ones are still a single piece of wood. You have to be careful to stay away from the spinning paddle when turning the handle.
Wooden spoons seem to always sell well at craft fares.
PBthecat
#3 posted 09-14-2010 01:04 AM
Yup I think the ball rasp is the tool. Thanks!
View bill1352's profile
bill1352
130 posts in 3243 days
#4 posted 09-14-2010 04:52 AM
I have a friend that does it for a living, has for 20 years. He has a router set up for everything from spoons to ladels. Band saws the handles. He was going to send me a pic of the set up but hasn’t yet.
-- Keep Your Stick On The Ice
View snowdog's profile
snowdog
1166 posts in 4104 days
#5 posted 09-14-2010 02:28 PM
I tried my hand at spoons and found it enjoyable to do it by hand, carving tools and a bit o band saw. I should go down and cut another blank today now that you bring it up. Good luck
View hairy's profile
hairy
2752 posts in 3653 days
#6 posted 09-14-2010 04:45 PM
You could change your process. Carve out the bowl first, cut out the outside last. It can be done with a gouge, or power tools.
Doing it that way gives you more support to the work piece. It’s easier to dish out a larger piece, more to hold on to.
-- My reality check bounced...
snowdog
#7 posted 09-15-2010 01:12 PM
That is a great idea Hairy, I’ll have to try that one time and see how it works.
