Epoxy Pinholes
Forum topic by texanbuildings posted 02-02-2017 06:46 PM 567 views 0 times favorited 5 replies Add to Favorites Watch
View texanbuildings's profile
texanbuildings
1 post in 626 days
02-02-2017 06:46 PM
Topic tags/keywords: epoxy pinholes mesquite voids cracks
I am making several projects from mesquite slabs. Using west systems epoxy to fill voids and cracks.
After initial sanding some pinholes appear in epoxy and I apply more epoxy to small holes. In some of the holes the 2nd application of epoxy does not fill hole after sanding. Some of the holes I have tried to fill 3 or 4 times and the epoxy will not fill pinhole.
Any tricks to get epoxy to fill pinholes?
5 replies so far
View MrUnix's profile
MrUnix
6948 posts in 2347 days
#1 posted 02-02-2017 09:14 PM
Open them up a little with a dremel or similar and heat the epoxy and work piece slightly so it flows better. Putting epoxy in the pinhole and then agitating it with a toothpick or paper clip after application will also help remove any bubbles that may still be present.
View papadan's profile
papadan
3584 posts in 3516 days
#2 posted 02-02-2017 09:20 PM
Your pin holes are air bubbles, don’t mix the epoxy too aggressively. As brad said, a little heat will help the epoxy flow better, just not too hot.
View shipwright's profile
shipwright
8086 posts in 2946 days
#3 posted 02-03-2017 12:33 AM
After the initial application, play a heat gun over the surface. It will heat and expand any bubbles and it will thin the material a bit. The combination of the two should make the bubbles rise and pop on the surface before the epoxy crosslinks.
Use a special self levelling formulation made for bar tops.
Fixing the pinholes after the fact is a lot of unnecessary work.
View Steve Peterson's profile
Steve Peterson
391 posts in 3230 days
#4 posted 02-03-2017 06:58 PM
I think the toothpick idea sounds like the best idea for getting the epoxy into the holes.
-- Steve
View Jim Finn's profile
Jim Finn
2682 posts in 3070 days
#5 posted 02-10-2017 01:41 PM
I use a finishing resin for this. Zpoxy is a thin epoxy and will penetrate a deep crack very well. It is a 30 minute epoxy and does not bubble.
-- No PHD just a DD214 Website> craftingcouple.com
