Plywood edging question
Forum topic by dfox52 posted 02-02-2017 03:31 PM 452 views 0 times favorited 5 replies Add to Favorites Watch
View dfox52's profile
27 posts in 1627 days
02-02-2017 03:31 PM
I would like some opinions on applying edging to plywood. I am making an oak TV credenza project. I usually glue-up boards to make my tops and bottoms but this time around I thought I would try using oak plywood and a router edging bit set to apply a 1 1/2 inch strip of solid oak edging. But I got to thinking… Should I miter the corners of the edging to hide the end grain? Or just butt joint the side pieces up to the front and back edges? Just asking because it seems like mitered corners would be a “dead give-away” that it is not solid oak slab. So do you miter or not?
5 replies so far
4908 posts in 2426 days
#1 posted 02-02-2017 03:40 PM
I do if the corners are exposed like on tops and bottoms. But it seems to me it’s still a “dead giveaway” that it’s not a solid slab since grain doesn’t run along the ends normally. That aside, it just makes a cleaner looking piece. If you want solid slab look, you cold make the end piece look like a breadboard end.
View Lazyman's profile
1811 posts in 1321 days
#2 posted 02-02-2017 03:44 PM
You could always mimic whatever joint you are using to join the PW panels. For example, if you are using a rabbet, make the edging with a matching faux rabbet.
Note that since they have been using veneer for a couple hundred years now, even in very finely made antique furniture, they have been hiding the edges for a long time now so I wouldn’t worry too much about this.
View pintodeluxe's profile (online now)
5594 posts in 2746 days
#3 posted 02-02-2017 04:03 PM
If it were just shelves, and not in a terribly visible location, I would use tongue and dado joints. I make them at the tablesaw with a dado blade. Self aligning, and no special bits needed.
However, since the top will likely be more visible, you can use faux breadboard ends to hide the “end grain.”
Personally, I would use plywood for the carcase, and a solid wood top. Of course it all depends on what design you are working with.
View johnstoneb's profile
2817 posts in 2106 days
#4 posted 02-02-2017 04:17 PM
It doesn’t matter what you do. You can’t disguise the fact it is a plywood top. Solid wood glued to the edges looks good and hides the plywood edges very well. I have used solid wood to hide the edges of plywood shelving and will again. Any of the suggestions you have been given above work well. It comes down to your choice.
-- Bruce, Boise, ID
#5 posted 02-02-2017 04:38 PM
Thanks for all the quick replies! This is my first time using plywood so I will see in the end how it looks. I think johnstoneb is right that “you can’t disguise that it is plywood.” So I think I should focus on what looks best using what I am using. Thanks a bunch!!
