glueing sandpaper
Forum topic by mbendel posted 09-13-2010 07:58 AM 854 views 0 times favorited 3 replies Add to Favorites Watch
View mbendel's profile
mbendel
2 posts in 3052 days
09-13-2010 07:58 AM
Topic tags/keywords: question sanding
Hey
I build bamboo fly rods and need to find a glue to adhere sandpaper to aluminum disks of a roughing mill spinning 12,000 on a router. Epoxy and contact cement fail, CA glue works ok. Any suggestions?
3 replies so far
View wysong's profile
wysong
17 posts in 3061 days
#1 posted 09-13-2010 08:24 AM
Contact cement
but your speed sounds to fast to sand anything though
-- Hutch
mbendel
#2 posted 09-13-2010 08:32 AM
I should follow up and add that the 36/50 grit is really cutting the strips into rough 60 degree triangles.
View David Kirtley's profile
David Kirtley
1286 posts in 3237 days
#3 posted 09-13-2010 03:13 PM
I would go with the pre-made diamond or carbide disks. You can pick up the small ones for a rotary tool or big ones that they use on angle grinders. You would go through the sandpaper too fast at those speeds.
