Temporary Table/ Saw Horse
Forum topic by devann posted 02-01-2017 11:07 PM 642 views 0 times favorited 6 replies Add to Favorites Watch
View devann's profile
devann
2246 posts in 2687 days
02-01-2017 11:07 PM
This is a tool review of sorts. I’m posting this for the carpenters, new woodworkers, and people with limited shop space. I scored this tool, fixture, work support from a friend that is in the junk / resell business. Here’s a couple pictures of the tool, fixture, work support, whatever one wants to call it.
closed;
open;
Now I have no idea what this is called or what it was originally made for. But it has been great for cutting plywood, siding, etc… without pinching the saw blade, causing kickback. It’s also make a nice quick work table that doesn’t sag regardless of a less than prefect surface to setup on.
A friend saw this tool and wanted to get one for himself. I told him that I saw something very similar at a Lowes store not long after I got this one. We checked, they don’t sell the model I saw in the store anymore. What they’re now selling is a smaller version barely big enough for a half a sheet of plywood. That said, we went online and found the maker’s website. There you can find models similar in size to the one I have. Myself, I haven’t used the Centipede version so I can’t write a tool review about the fixture. That’s why I’m posting this info here in the forum section.
By all appearances I would guess that what Centipede.com is selling would work as well as the fixture I’m using.
While this won’t replace all the uses for traditional saw horses, it does complement having saw horses making some work easier & safer than traditional saw horses.
http://centipedetool.com/
P.S. if anybody knows what the item I have pictured was originally made for I’d appreciate learning about it.
runswithscissors
2750 posts in 2020 days
#1 posted 02-03-2017 02:27 AM
Seems like you would have to be very careful to avoid sawing into the support tops. Maybe put down a sacrificial sheet of thick insulating foam first?
devann
#2 posted 02-03-2017 02:59 AM
Yes, you do want to be aware of where your blade is cutting if not using a sacrificial surface. When using any work support I typically use a sacrificial piece of wood when making a lot of cuts, be it a sheet of OSB or plywood. I usually use the cheapest material I have on hand to cut on for any application, whether using this setup or traditional saw horses. This work support doesn’t replace traditional saw horses when cutting longer pieces of lumber like rafters, joist, stair stringers, etc…..
Mostly I like to use this with a sheet of 3/4’ plywood for a quick, flat work surface on the job site. Generally it’s used for work assembly, and tool support.
View r33tc0w's profile
r33tc0w
152 posts in 479 days
#3 posted 02-03-2017 03:35 AM
That is a pop Up Display for a convention booth, backwall, etc. Used in the signage industry. However, this appears to be missing the locking arms which allows it to stand vertical. The velcro around the perimeter secures a dye sub stretch fabric print to the frame
http://www.theexhibitorshandbook.com/portable-displays/collapsible-displays/hopup-tension-fabric
-- Matthew 13:53-58
devann
#4 posted 02-03-2017 05:00 AM
Thanks r33tc0w. There are some hooks that are hard to see in the photo. There are also some decals indicating
<top
It works well for what I use it for.
runswithscissors
#5 posted 02-03-2017 05:11 AM
View Woodchuck2010's profile
Woodchuck2010
707 posts in 853 days
#6 posted 02-03-2017 02:08 PM
That indeed is the centipede. It does look like you have it upside down in the pic. I have a small one that I got at Lowes. It works pretty good for some things and supports a lot of weight. Mine came with some clamps and hold downs. Not bad for free! On second thought I think r33tc0w is correct. It looks a little different then mine. Same idea, different use.
-- Chuck, Michigan,
