Miter saw stand wings: fixed or flappy?
Forum topic by Bcemail posted 02-01-2017 08:55 PM 377 views 0 times favorited 1 reply Add to Favorites Watch
View Bcemail's profile
Bcemail
16 posts in 593 days
02-01-2017 08:55 PM
Found a lot of good plans for miter saw stands here and around the web. Planning on putting one together soon. It will be pretty simple since I want to use whatever scraps I have around.
My original thought was to have folding wings. Has anyone had any problems with these not being sturdy enough? Or getting out of line with the saw? I started to think that fixed might be simpler and since it would be long but narrow it wouldn’t take up too much space when rolled to the side.
Thanks!
1 reply so far
View devann's profile
devann
2246 posts in 2778 days
#1 posted 02-01-2017 10:07 PM
For my 2ยข I like removable. I need portability. Sometimes I need to pack up and travel with mine. One of the easiest ways I’ve found to make wings is score you some commercial aluminum door/window jambs.
I made a set. Use the jambs for the fence / wing structure and screw plywood to the bottom (inside of jamb) to set material on to be cut. Removable/ adjustable legs can be easily made. A little fiddling to make the saw/wing connection. Don’t forget to notch wing fence at the saw, allowing for the miter saw fence to expand/contract as needed when changing miter saw bevel settings. Straight, strong, light weight.
