planing large table top
Forum topic by willhime posted 02-01-2017 05:58 AM 831 views 0 times favorited 14 replies Add to Favorites Watch
View willhime's profile
willhime
100 posts in 1442 days
02-01-2017 05:58 AM
Topic tags/keywords: resource jig tip question trick
I made this table I realize now the most difficult way probably. I made 3-4 board sections of edge grain, then glued it to the next section of edge grain because my planer can only do 12” or less at a time. I’m trying to figure out the best way to get a clean level surface now. I’ve made a router planer jig in the past for cutting boards, but this is obviously much too large for that…at just over 37” wide. The longest hand plane I have is a 14”. Any ideas or suggestions would be appreciated.
- Will
-- Burn your fire for no witness
14 replies so far
View Rick_M's profile
Rick_M
11090 posts in 2283 days
#1 posted 02-01-2017 06:20 AM
I flattened all my tables with hand planes but I don’t see why it would be too wide for a router planing jig, just make wider rails.
-- http://thewoodknack.blogspot.com/
View OSU55's profile
OSU55
1515 posts in 1893 days
#2 posted 02-01-2017 01:08 PM
A 14” plane will do it, as well as a longer cross slide for the router. The router may sag a bit in the middle, but will rough it out, and the plane can finish it.
View dday's profile
dday
138 posts in 1333 days
#3 posted 02-01-2017 01:43 PM
Might be too late for this one, but I did a similar thing. I took sections of 6 boards, glued and bolted together, ran them through my planer ( had to build an extension table front and back because of the weight) to get them to be the exact same thickness, then laid them on a perfectly flat service before gluing them together and running threaded rod through all of them. They were almost perfectly flat after that and required minimum sanding.
willhime
#4 posted 02-01-2017 05:43 PM
the problem with the wider rails is that they’ll have to be free standing from the floor, but it’s looking like that’s my only option. So I guess I’ll try that then hand-plane finish it.
dday- yeah, it’s a little late for that. Lesson learned though. That’s kind of how I planned to do my next one though so it’s good to know that works well.
View mike02130's profile
mike02130
167 posts in 576 days
#5 posted 02-01-2017 05:57 PM
Belt sander
-- Google first, search forums second, ask questions later.
View pintodeluxe's profile
pintodeluxe
5565 posts in 2716 days
#6 posted 02-01-2017 06:15 PM
I take my large tabletops to a commercial shop in my area. They have an amazing 50” wide planer / drum sander. It hits the surface with a helical planer head, then two grits of sandpaper, all in a single pass.
Their labor rates are quite reasonable, and it saves me a lot of work.
And talk about flat. Wow, perfectly smooth and flat.
View HorizontalMike's profile
HorizontalMike
7747 posts in 2817 days
#7 posted 02-01-2017 06:52 PM
I vote for the sander. You have grain changing directions all over the surface and that pine is rather soft and likely to splinter and tear. You have already planed the 4x laminates, should you should be rather close on the final glue-up. SAND it.
View KelleyCrafts's profile
KelleyCrafts
2705 posts in 642 days
#8 posted 02-01-2017 09:48 PM
Rip cut it at the glue line in a few spots, run it through your planer then glue it back up.
-- Dave - http://kelleycrafts.com/ - pen blanks - knife scales - turning tools
View Carloz's profile
Carloz
1147 posts in 495 days
#9 posted 02-01-2017 10:28 PM
Use your hand plane across the grain and then along. A Jointer plane would do this job better but your 14” will do.
Especially that the wood you use is very soft. Be careful around the knots to avoid tearout.
9937 posts in 3551 days
#10 posted 02-01-2017 10:33 PM
Unless you want it to look rough, take it to
a shop with a wide belt. It shouldn’t cost
more than $40 or so and will save you hours
of work.
Unless you A. like the look of tearout in pine,
B. like the look of tearout patched with putty.
View rwe2156's profile
rwe2156
2796 posts in 1384 days
#11 posted 02-02-2017 04:51 PM
Well, it all depends …..
What’s it for? How flat does it have to be?
How rustic do you want it to look? (Looks pretty rustic to me ;-)
I’ve got the hand planes, but that’s WAY to big a job for me.
Router sled worked fine on this bench 35” wide you just need a stout sled that won’t flex:
View BobBlarney's profile
BobBlarney
49 posts in 1039 days
#12 posted 02-02-2017 09:09 PM
What s it for? How flat does it have to be?
I ve got the hand planes, but that s WAY to big a job for me.
Router sled worked fine on this bench 35” wide you just need a stout sled that won t flex:
- rwe2156
Hmm, if you cut plowed across with the router sled about every 4-6 inches, you could probably finish the job quicker and with a lot less dust with the jackplane by connecting the furrows.
-- Curator, Museum of Unfinished Projects
View ArtMann's profile
ArtMann
824 posts in 719 days
#13 posted 02-03-2017 03:35 PM
Uhhh. I’m guessing the hand held belt sander was invinted after the depression. Doesn’t your policy preclude the use of such a tool?
Belt sander
- mike02130
mike02130
#14 posted 02-03-2017 04:13 PM
ArtMann,
Bad guess.
The portable belt sander was invented in 1927—two years before the depression—by Porter Cable. http://ruudbaaijens.nl/wp-content/uploads/2013/01/RuudBaaijens_EPD_SandingMachine-v2.pdf
I did not ask the question, I only answered it.
I may not need post depression tools, but I do use them.
