Gluing wood for large plaque
Forum topic by Boydman posted 09-12-2010 07:19 PM 1000 views 0 times favorited 3 replies Add to Favorites Watch
View Boydman's profile
Boydman
14 posts in 3163 days
09-12-2010 07:19 PM
Need some advice, I am making a 17”X20” wall plaque, i have jointed, planed and edge glued three 6” wide pieces 5/8” think red oak. The wood was rough sawn and air dried over 1 and 1/2 years. The piece is presently flat, but I worry as humidity changes it may cup due to the large size? I plan to seal the plaque with polyurethane. Would it be better to cut the wood into thinner strips and alternate the grain to prevent warping or cupping? Or are there other alternatives such as relief cuts in the back? All help and suggestions would be much appreciated.
Thanks Bob
-- Bob, Abilene Texas
3 replies so far
View ND2ELK's profile
ND2ELK
13495 posts in 3797 days
#1 posted 09-12-2010 08:12 PM
It will not cup in most cases if you rotate your boards. If you look at the end of the boards you can see where the grain goes up or down. One up, next one down and one up. I usually glue no more than 4” wide boards for large plaques or panels. Your boards being 6” wide might have a problem unless you rotated the boards and the you might luck out.
God Bless
tom
-- Mc Bridge Cabinets, Iowa
View lew's profile
lew
12100 posts in 3779 days
#2 posted 09-12-2010 08:19 PM
If it’s 5/8” thick flat sawn red oak, it may cup. I think I would rip the boards to 3” or 4”, like Tom said and alternate the grain pattern.
BTW, love your Basset! Ours is named Quigley.
Lew
Boydman
#3 posted 09-13-2010 03:33 AM
Thank you for the help gentlemen, I did not alternate the grain, i got too caught up in the look of the grain pattern and the color consistency. I will rip the existing board, joint, alternate and reglue. Thanks
