Desk Joint Question
« back to Joinery forum
Forum topic by loyalstricklin posted 01-31-2017 02:58 PM 597 views 0 times favorited 8 replies Add to Favorites Watch
View loyalstricklin's profile
loyalstricklin
3 posts in 625 days
01-31-2017 02:58 PM
Topic tags/keywords: wood joint joint
I’m making a desk with joints similar to the ones below. I’m currently doing test pieces before cutting them out of walnut.
My question is, what is the best way to make the curves? My current idea is to cut the rough shapes out on the bandsaw, and then use an oscillating edge sander (a rigid) to sand the wood down to my outline.
Any other advise? Also, is there a term for joint like this?
Thanks,
Michael
8 replies so far
View CharlesA's profile
CharlesA
3341 posts in 1942 days
#1 posted 01-31-2017 03:08 PM
My sense would be that with this kind of joint, you get it close with methods you describe before glue up, but you’ll have to do hand work with rasp, sandpaper, etc. for the final look.
View jmartel's profile
jmartel
8155 posts in 2294 days
#2 posted 01-31-2017 03:13 PM
Oscillating spindle sander or use a router with a template. As far as the joint goes, it’s probably just a normal Mortise & Tenon that’s been shaped.
View Kazooman's profile
Kazooman
1144 posts in 2096 days
#3 posted 01-31-2017 03:26 PM
I just noticed that prior to this one I have 666 posts. Must be some kind of omen.
At any rate, I would second the templates and router comment. One for the top curves and one for the bottom. Spend the time to get it as accurate as possible and then all of the curves will be identical.
View DrDirt's profile
DrDirt
4464 posts in 3886 days
#4 posted 01-31-2017 03:48 PM
That will work, but I would modify the design a little, such that the legs have some of the curge in them and teh stretchers are straighter – - to have less short grain at the joint, that will want to break off.
So more like this to keep max long grain.
View sras's profile
sras
4883 posts in 3273 days
#5 posted 01-31-2017 03:54 PM
I’d suggest glue up and then shape. That will eliminate the exposed fragile ends of the rails.
loyalstricklin
3 posts in 625 days
#6 posted 01-31-2017 05:34 PM
That’s actually how I’m constructing it…with the little notes that meat the cross members. I bought the rigid oscillating sander this morning and did two legs. I’m pleased with the results. If all goes well, I’ll be making more of these tables and will used a router and template for production work.
Thanks to everyone who answered! I appreciate it.
- DrDirt
loyalstricklin
3 posts in 625 days
#7 posted 02-18-2017 03:29 AM
I ended up using an oscillating sander. It was a pain. I’d recommend useing a router/table and making a template. I’ll definitely be doing that on all future projects like this. I have a few smaller gaps. probably could have used my shoulder plane a bit more, but I like it well enough.
View Mike_D_S's profile
Mike_D_S
482 posts in 2359 days
#8 posted 02-18-2017 04:56 PM
Ah, the dreaded gap that no one else will ever see or notice. I tend to obsess about this stuff, but my neighbor takes a bit more practical approach. He always tells me that anybody in my house looking at the piece close enough to see that gap just needs to go home.
Its looking good to me.
Generally, I use the spindle sander to create the template in 1/4 MDF and then use bandsaw to clear the bulk of the waste and router with the template to clean up.
Mike
-- No honey, that's not new, I've had that forever......
