| Forum topic by patcollins | posted 987 days ago | 888 views | 0 times favorited | 18 replies | ![]() |
987 days ago |
Would a sled made from particle board be ok, or should I stick to plywood or MDF? If not why? |
18 replies so far
#1 posted 987 days ago |
I suppose it depends on what kind of sled … particle board doesn’t hold up well in snow! Kidding aside, it really does depend on what kind of sled. A tablesaw crosscut sled might work fine with a particle board base. But if you are making a sled with clamps to hold the workpiece, the screws holding the clamps might have a tendancy to pull out. And if you were making a small sled, particle board might not have enough structure to keep it from breaking. -- http://www.peteroxley.com -- http://north40studios.etsy.com -- |
#2 posted 987 days ago |
Greetings patcollins, -- " Don't ever wrestle a pig in a mudhole....he'll be having more fun than you..!! |
#3 posted 987 days ago |
3/4” MDF, and wax it. -- david roberts, spinning Tales from Topographic Oceans, no, really. |
#4 posted 986 days ago |
Actually the piece of pb i got is pretty smooth on the flat surfaces, so I dont think that part would be a problem. Today Lowes didn’t have any 2’x4’ sheets of hardwood plywood so I saw the PB was like $5 so i grabbed it figuring I could use it for something else if it wouldnt work for a sled. I wasn’t ready to buy an 8’x4’ sheet today. |
#5 posted 986 days ago |
PB is worthless. I can not think of one job that it excells. My guess is that it was invented to cut costs at the expence of quality. My house was built in ‘86. The top layer of flooring in PB. If you spill a glass of water you have a hump. -- Tom, MI, SC |
#6 posted 986 days ago |
Jarrod might be right. I use PB too for certain jigs, like crosscut sled, box joint jig, router mortising jig…. Peter has a good point about how it should/can be used… it’s good for flat surfaces, but nothing where you’re going to be screwing in clamps, since it’s very weak that way. |
#7 posted 986 days ago |
Particle board is just like MDF only it’s not been to finishing school—it’s less refined. Any surface screw that’s involved in a TS sled would not have enough stress on it to pull it away. Typical screws don’t work well in the edge of PB (and I’m thinking of 3/4 thick as a default thickness here) but biscuits do. Suppose you had a PB sled and were using stop blocks in it, and moving them about for various projects. -- "...in his brain, which is as dry as the remainder biscuit after a voyage, he hath strange places cramm'd with observation, the which he vents in mangled forms." --Shakespeare, "As You Like It" |
#8 posted 986 days ago |
I like baltic birch for this application, MDF or particle board would be to heavy for this 71 year old to lug around for saw cuts. When I do use MDF, I have help lifting it on the bench. I can remember the days when I use to hang 5/8 X 12’ sheets of dry wall on the ceiling. Those days are all over. -- TheOldTimer,Chandler Arizona |
#9 posted 986 days ago |
Is particle board small fiber? Basically saw dust compressed into a sheet? Maybe the stuff I am talking about is different. OSB= large chips. PB= saw dust. In my region, SE coastal, the PB has to be (IMHO) totally encapsulated or it will conform to an uneven supporting surface. In my experience: build a jig and lay it on top of say a screw driver, a week later it will be warped. One drop of water (sweat) and it will raise like a zit. Maybe in areas of the country that don’t have a widely fluctuating humidity have better luck with PB? -- Tom, MI, SC |
#10 posted 986 days ago |
Particle board that I got has particles a bit smaller than the grains of kitty litter. OSB = strings glued together |
#11 posted 986 days ago |
Do you have MDF or psrticle board? Particle board looks like wood chips and would work as long as the surface is smooth enough and supported well with the fence. MDF would be a much better choice for a sled. -- Brian, Lebanon PA, If you aren’t having fun doing it, find something else to do. |
#12 posted 985 days ago |
Sorry to confuse things… again. I think Lee hit it on the head about #2 being unfinished MDF. My problem with warping is probaly due to the fact that I can’t seem to get the humidity level below 50% in my uninsulated shop without running my power bill thru the roof. -- Tom, MI, SC |
#13 posted 985 days ago |
Particle board works fine for many applications. I would use it to make a TS sled or any lind of jig. Some have particle and chip board (OSB) confused. Oriented Strand Board looks like, and is, wood chips glued together in layers that are oriented in opposite directions for each layer. Particle board is lighter than MDF and it will take screws better than MDF. It’s almost as smooth as MDF. Most melamine panels are particle board with a plastic coating. I always use confirmat screws when running into the edge of particle board. They were designed for this type of application, however, I normally use biscuits when building anything out of particle board. Particle board also takes wood or vinyl edge band tape very well. Particle board will expand if it gets wet, but MDF will blister, so moisture comparison is pointless. If the application is subject to high moisture, I would not use either one. -- I don't make mistakes, only design changes....www.dgmwoodworks.com |
#14 posted 985 days ago |
I have used a mdf sled for over a decade with no problems but I have noticed short pieces of particle board bend up in only months sitting around the shop. |
#15 posted 985 days ago |
I have used MDF and what I call particle board (larger pieces glued in) for table saw sleds and have never had any major problems. The one thing I have noticed is that it seems I have to use extra wax on them to make them slide easy, especially on the MDF. I think the nature of MDF soaks up the wax more than solid wood. I say this because I also notice that after having to coat it good several times, it eventually soaks up enough that it doesn’t require no more waxing than anything else. The only time I had a sled warp out of MDF was once I leaned one against the wall, then leaned more lumber against that, then more. By the time I needed the sled again, it had warped. I think the weight of the other lumber done it though, because that’s the only time it happened. Normally I hang my sleds on the wall. I drill a hole in a place on it that won’t hurt it and hang it from a nail on the wall so that it lies flat against the wall. |
| Forum | Topics |
Woodworking Skill Share
8798 |
Woodturning
224 |
Woodcarving
28 |
Scrollsawing
61 |
Joinery
82 |
Finishing
1538 |
3556 |
15815 |
Hand Tools
2039 |
Jigs & Fixtures
496 |
Wood & Lumber
2847 |
810 |
Focus on the Workspace
903 |
766 |
Woodworking Trade & Swap
2742 |
LumberJocks.com Site Feedback
1547 |
Coffee Lounge
6166 |
