Making Chisels
« back to Hand Tools forum
Forum topic by John posted 01-31-2017 02:01 AM 676 views 0 times favorited 12 replies Add to Favorites Watch
View John 's profile
John
253 posts in 3488 days
01-31-2017 02:01 AM
Since screwdrivers are made of hardened steel, is it possible to heat to soften, reshape then reharden? My main reason I ask is cause I have had a couple of small projects where I need an 1/8” chisel but where I live, there’s none to be found. I would like to make a few small tools and screwdrivers are easy to come by.
-- John
12 replies so far
View Lazyman's profile
Lazyman
2288 posts in 1474 days
#1 posted 01-31-2017 02:13 AM
Won’t hurt to try. You could always just grind it without annealing and re-hardening. Just make sure that you don’t let it get hot enough to turn blue while you grind it. Just keep a cup of water next to the grinder and dip it before it gets too hot.
If you want to go the route of annealing, shaping, hardening and tempering, you might want to look up spark testing to see how much carbon is in the steel. This may give you a better idea how well you will be able to re-harden it afterwards. You probably want a steel that at list .50 % carbon. BTW, you will also want to temper the steel after you harden it so it is not too brittle. This means that you may want to remove it from the old handle because you have to put it in a toaster oven, for example, and most handles won’t take that kind of treatment.
View Woodknack's profile
Woodknack
12245 posts in 2466 days
#2 posted 01-31-2017 03:04 AM
You’ll want good quality screwdrivers
John
#3 posted 01-31-2017 03:42 AM
I’ll have to look into this spark testing.
-- John
View TungOil's profile
TungOil
996 posts in 581 days
#4 posted 01-31-2017 04:29 AM
Maybe buy a cheap 1/4” chisel and grind it down?
-- The optimist says "the glass is half full". The pessimist says "the glass is half empty". The engineer says "the glass is twice as big as it needs to be"
View SuperCubber's profile
SuperCubber
1030 posts in 2371 days
#5 posted 01-31-2017 05:08 AM
What about an 1/8” drill bit? Grind the non fluted end and sick it into a handle.
-- Joe | Spartanburg, SC | "To give anything less than your best is to sacrafice the gift." - Steve Prefontaine
John
#6 posted 01-31-2017 06:15 AM
The problem with converting a 1/4” chisel is the blades are not long but I might not have a choice.
The 1/8” drill bit option may work. I have a few that are approximately 8” long. Now why didn’the I think of that.
Thanks for your input.
-- John
View MustacheMike's profile
MustacheMike
261 posts in 2175 days
#7 posted 01-31-2017 11:29 AM
Here is a video on that subject we did a while back https://www.youtube.com/watch?v=G8Gn9CJ_0oE
Don.t forget to subscribe if your not already.
-- You can trust Mike -" because I will never pull your stash!" See my show weekly at Stumpynubs.com
John
#8 posted 01-31-2017 03:14 PM
Mike, I found your video last night while searching the tube. Great video! I like the way you made your point without loud unnecessary music in the background. Also found a few that some made from old files. I’m thinking I can get a nice Mortise Chisel from one of my old Harbor Freight files since they’re not any good for anything else. Thanks again for replying.
-- John
View Planeman40's profile
Planeman40
1206 posts in 2847 days
#9 posted 01-31-2017 03:36 PM
Try using concrete nails available at Lowes and Home Depot. These are hardened and have a broad flat head like hand cut nails that would make into a nice small chisel. Add a handle and you should be ready to go. And a box of them is CHEAP!
View LittleShaver's profile
LittleShaver
346 posts in 706 days
#10 posted 01-31-2017 06:53 PM
Old files work great. I inherited about 20 pounds of old chisels from my grandfather about 40 years ago. Been moving them all around the country all that time until about 2 years ago. That’s when I went on a “make your own tools” kick. I’ve made a set of chisels (1/8 – 1”), a plane, a bird cage awl, and a turning scraper out of old files.
It takes some time to get them into the proper shapes without bluing the steel. Lots of dipping in the bucket of water. A worn 180 grit belt on the belt sander seemed to work best to get rid of the file teeth. Lots of dipping in the bucket of water.
I still have 20 or so triangle files in the pile. Perhaps I’ll just pass them along to my son.
-- Sawdust Maker
View Andre's profile
Andre
1963 posts in 1892 days
#11 posted 01-31-2017 09:08 PM
I used an old small flat file, annealed it to shape then retempered.
John
#12 posted 01-31-2017 10:01 PM
Would have never even though of concrete nails. I’ll have to remember that one for small things. Seems like the old file thing is the best for me since i’m looking to make it as long as possible, kinda like a Mortise chisel. Again, thanks for everyone’s replys
-- John
