Bandsaw blades - reue old
Forum topic by snowdog posted 982 days ago 957 views 1 time favorited 11 replies Add to Favorites Watch
View snowdog's profile
snowdog
1115 posts in 2151 days
982 days ago
I have several old band saw blades (97 inch I think), not really old just dull. I hit a nail on one..etc
What can I do with them? Can they be resharpens? For $35 bucks the seem like disposable items. Besides throwing them in the trash what can I do with them?
11 replies so far
View barryvabeach's profile
barryvabeach
159 posts in 1211 days
#1 posted 982 days ago
If you search Youtube, you should find a video of a guy using a dremel type tool and a cutoff disk to resharpen bandsaw blades http://www.youtube.com/watch?v=wht-30Oh4zQ Never tried it myself.
View docholladay's profile
docholladay
1258 posts in 1227 days
#2 posted 982 days ago
I read an article once about sharpening a bandsaw blade using a similar technique to sharpening a handsaw. They clamped the blade between two pieces of wood. The pieces of wood are positioned just below the gullet of the teeth. Then the teeth were filed with a an appropriate sized chain saw file that fits the radius of the gullet. Then they literally used a hand saw saw set to set the teeth.
Other than that, I have also heard of people taking sections out of band saw blades to use in making blades for any of the various type of frame/buck saws where the blade is held in tension in a frame.
I also suppose that you could actually make small card scrapers from wider blades.
Any of you galoots have any other ideas out there? You’ll be amazed at what some of these guys can come up with. They really give new meaning to the idea of recycling.
-- Hey, woodworking ain't brain surgery. Just do something and keep trying till you get it. Doc
View zwwizard's profile
zwwizard
171 posts in 1877 days
#3 posted 982 days ago
$35.00 seems kind of high for a blade, unless, they are a special type of blade. I pay $11.00 to $15.00 a blade (109”, 112”) Bi-metal 3/4” $38.00.
-- Richard http://www.PictureTrail.com/gallery/view?username=thewizz
View Jim Finn's profile
Jim Finn
1062 posts in 1090 days
#4 posted 982 days ago
I have used a broken band saw blade in my scroll saw. Cut to legnth and used it to cut the fake stone used on house fronts here in Texas. Cuts it like butter. I have sculpted a few items with this material. Dremmel tools also cut it easier than wood. Very dusty process though.
-- In God We Trust
View Bill White's profile
Bill White
2603 posts in 2128 days
#5 posted 981 days ago
I cut 12” sections (6 or 7), tape the ends together into a bundle, and use ‘em to dress buffing wheels.
Bill
-- bill@magraphics.us
View Dennisgrosen's profile
Dennisgrosen
10854 posts in 1283 days
#6 posted 981 days ago
besides small scrapers formed to what you want to be scrabed on different concave and hollow things
you can reuse the blades if you make a scratshtool and file of the teeth
look at this vidioclip
http://lumberjocks.com/davemoorefurniture/blog/15014
I´m sure you will find other purpose as well, now don´t forget to share new ideas…lol
good luck
Dennis
View WoodyG's profile
WoodyG
31 posts in 1341 days
#7 posted 981 days ago
You know these marking knives tool companies sell for $30 to $40 well, I made a marking (double ended) out of a blade. I fashioned a 6” handle and piece of the blade 9” long. I sawed a slot in the wood handle length wise with a hack saw…then pushed the band saw blade in leaving 1 1/2” sticking out of both ends. I then sharpened both ends…one left hand and one right hand….on the bench grinder. I then polished the grinder marks out of the blade….presto….a double ended marking knife and I might add be careful with it because you are exposed to a razor sharp blade no matter how you hold it. Might be a good idea to cover the end you are not using. Happy marking all you dovetailers???
-- WoodyG
View ChuckV's profile (online now)
ChuckV
1748 posts in 1695 days
#8 posted 981 days ago
I took a decorative inlay workshop. We made the scrapers from old bandsaw blades. We roughed out the shape using a grinder and completed them with a file.
-- "Too much hurry ruins the body. I'll sit easy … fan the spark" - I. Anderson
View William's profile
William
7063 posts in 1010 days
#9 posted 981 days ago
Another use for old bandsaw blades is to cut them about three inches long, bend each end into very small double-L shape, drill a small hole on each end, and use them to hang picture frames with. I think I may have confused the matter on that. If you’ve seen this type hanger though, you know what I mean.
I usually cut slots in the backs of my frames, but I’ve done this with a few band saw blades when my router bit wears out and I’m trying to finish without heading to the hardware store.
View TJ65's profile
TJ65
1332 posts in 1218 days
#10 posted 981 days ago
Glad you asked about this, as I was wondering about the same thing! :-)
-- Theresa, https://sites.google.com/site/tmj65treasure/
Dennisgrosen
#11 posted 980 days ago
here is another way of scratchstock
and there you can see what I ment about using a piece of the blade
http://villagecarpenter.blogspot.com/2007/12/scratch.html
Dennis
