Varnish in a bathroom?
Forum topic by ChrisForthofer posted 09-11-2010 05:46 AM 950 views 0 times favorited 3 replies Add to Favorites Watch
View ChrisForthofer's profile
150 posts in 2999 days
09-11-2010 05:46 AM
I am making a medicine cabinet for our guest bathroom, I dont much care for all the labor intensive sanding that poly requires between coats. Being a finishing newbie I am wondering if a varnish would be suitable for a cabinet that will not be getting a terrible amount of wear and tear but will be exposed to a moist environment. If varnish wouldnt be suitable could you finish savy folks recommend something that would work? Thanks for the help in advance.
-- -Director of slipshod craftsmanship and attention deficit woodworking
3 replies so far
View Mark Shymanski's profile
Mark Shymanski
5621 posts in 3645 days
#1 posted 09-19-2010 07:02 PM
I am not that experienced in finishing, but from what I understand poly is probably the easiest finish to apply especially for the environment you describe.
View gul's profile
400 posts in 2894 days
#2 posted 09-19-2010 07:33 PM
maybe wood lacquer can come handy?
View Apex's profile
9 posts in 2793 days
#3 posted 09-21-2010 05:05 PM
Varnish wood be a good choice. Pick a varnish that is designed to be used outdoors. Lacquer is great if you have a spray gun as it drys very fast and goes on smooth.
Utah stair rail
