Help with a euro hinge disaster
Forum topic by JADobson posted 01-30-2017 12:24 AM 1638 views 0 times favorited 18 replies Add to Favorites Watch
View JADobson's profile
JADobson
1127 posts in 2191 days
01-30-2017 12:24 AM
Good evening jocks,
Just wondering if anyone has any suggestions for this problem. My three year old decided to hang off a cabinet door in my kitchen and pulled the door right out of the cabinet side. Took quite a lot of the substrate with the hinge. I’ve never used these materials before but thought if could fill the gap with epoxy and put as much back into place as I can. I’m hoping the epoxy will be strong enough to hold the hinge in place. Any help would be appreciated.
-- No craft is very far from the line beyond which is magic. -- Lord Dunsany — Instagram @grailwoodworks
18 replies so far
View Loren's profile
10477 posts in 3727 days
#1 posted 01-30-2017 12:34 AM
I would drill it out and plug with dowels,
then flush cut the dowels off, remove
the plastic inserts from the screws and
re-install from there.
View Rayne's profile
Rayne
963 posts in 1619 days
#2 posted 01-30-2017 12:35 AM
I would try to drill larger holes to where the screws went in, glue/epoxy some hardwood dowels in the holes, then drill for the right size screws for the hinge into the hardwood and attach. Whether that’s the “proper” thing to do or not, I couldn’t tell you, but I know would try it.
View Mike_D_S's profile
Mike_D_S
482 posts in 2294 days
#3 posted 01-30-2017 12:43 AM
If i was doing this repair, I wouldn’t worry too much about the look of the final repair, but more about how solid the repair was.
My solution would be to take a 1/2” forstner bit and drill a hole at the location of each screw hole, making sure not to go all the way through the door. Then buy some 1/2” dowel and glue the dowel into the hole. You’ll end up with a nice solid mounting point for the screws.
If the torn out section bother you, just fill it with wood putty that’s a close match. Since you have solid mounting for the screws, this will be cosmetic only.
The forstner holes are probably best drilled with a drill press with the depth locked so you don’t drill through, but you could probably also use a 1/2” bit in a plunge router if you clamp the router base down with the proper setting on the depth stop.
Hand held drill would work, but be careful with the depth.
Mike
-- No honey, that's not new, I've had that forever......
Mike_D_S
#4 posted 01-30-2017 12:43 AM
@Loren and Rayne,
Guess we were all typing at the same time.
Mike
View Madmark2's profile
Madmark2
381 posts in 668 days
#5 posted 01-30-2017 12:47 AM
I hate chipboard!
The correct fix is to replace the kitchen. Barring that the hinge pocket needs to be redrilled in solid material and the hinge relocated. You need a drillpress with a 35 mm (1-3/8”) Forstner bit. Drill 13/16” in at new location on door. Hold hing in place and drill the two #6 mounting holes – all 1/2” deep. Install hinge on door. Get helper to hold door in place while you mark cabinet side mtg holes. Predrill cabinet #8 and mount. Make sure the hinge tips go on each side of the frame (NA for frameless mount).
View waho6o9's profile
waho6o9
8288 posts in 2656 days
#6 posted 01-30-2017 12:54 AM
I’d add a 1/2 thick piece of hardwood 3” wide and use new hinges. assuming the door part is
okay.
There’s a plethora of hinge designs these days and you can mount them on the hardwood and be done.
waho6o9
#7 posted 01-30-2017 01:02 AM
Blum works well. I just go to the supply house and explain what I need to do and they bring out a couple of
different hinges and it always works out.
It’s similar to a face frame euro hinge install:
Rayne
#8 posted 01-30-2017 01:02 AM
@Loren and Rayne,
Mike
- MikeDS
My thoughts exactly. At least we universally agree on the solution. lol.
View jbay's profile
jbay
2485 posts in 979 days
#9 posted 01-30-2017 01:14 AM
I would tape off around the tear out as close as you can, Then fill with either bondo (my first choice) or wood filler.
Then I would drill and install dowels as mentioned.
JADobson
#10 posted 01-30-2017 01:23 AM
@Loren and Rayne,
Mike
- MikeDS
- Rayne
Thanks for the help everyone, this looks the path I’ll follow. Will there be any concern in glueing the dowels to the chip board? will regular yellow glue hold everything together?
I hate chipboard!
Yup.
View Rich's profile
Rich
3332 posts in 669 days
#11 posted 02-01-2017 06:09 AM
If you can get a clamp on it, I’d epoxy it back in as-is.
View Kelly's profile
Kelly
2050 posts in 3024 days
#12 posted 02-01-2017 06:47 AM
I’d just router and chisel out a square, then insert plywood with good old yellow glue. When dry, I’d re-drill the three holes and it should be good to go.
I did this on a MUCH bigger scale when repairing a heritage home door and no one could tell the repair had been done.
View AlaskaGuy's profile
AlaskaGuy
4264 posts in 2389 days
#13 posted 02-01-2017 07:57 AM
I d just router and chisel out a square, then insert plywood with good old yellow glue. When dry, I d re-drill the three holes and it should be good to go.
- Kelly
It the base plate on the cabinet (not the door) Just need what Loren and some other said.
View robscastle's profile
robscastle
5168 posts in 2284 days
#14 posted 02-01-2017 11:00 AM
You could just relocate the hinge.
-- Regards Rob
AlaskaGuy
#15 posted 02-01-2017 04:57 PM
No need to relocate the hinge. If you do, then you have to deal with 3 holes on the back of the door.
I worked of over 18 years at our local school District in the maintenance dept. In that time I repaired many hinge
like that, that pulled out of the cabinet. Keep it simple and do what Loren said. That’s all the really needs to be done.
This is a “keep it simple project’’.
