Milling Lumber from Logs - how do you Debark?
Forum topic by PurpLev posted 09-10-2010 07:01 PM 11178 views 0 times favorited 24 replies Add to Favorites Watch
View PurpLev's profile
PurpLev
8534 posts in 3618 days
09-10-2010 07:01 PM
My last attempt at resawing logs to lumber, I debarked the logs using a recycled kitchen clever which stood up to the job quite well, but it made me wonder – how do YOU debark the logs? axe? other?
24 replies so far
View Woodcanuck's profile
Woodcanuck
128 posts in 2970 days
#1 posted 09-10-2010 07:21 PM
Not that I’ve done this a lot, but I’ve used an adze and a mattock. The mattock was a small hammer sized mattock, which I took the ‘blade’ to the grinder and sharpened to cut through the bark.
This worked pretty well, though my aim wasn’t great so I ended up with gouges in the wood…which in my case was for a crib for a dock so I didn’t care that much (helped let the kreosote soak in).
-- Ian - Life's a game, if you don't play, you can't win.
View jack1's profile
jack1
2103 posts in 3997 days
#2 posted 09-10-2010 07:24 PM
Have you tried a good veterinarian? ;0)
3809 posts in 3991 days
#3 posted 09-10-2010 07:25 PM
I just cut it off after slicing it. Usually in the squaring process on the Table saw.
If you are taking big stuff the guys usually turn the cant 90° and run the band saw on each side.
View CampD's profile
CampD
1653 posts in 3456 days
#4 posted 09-10-2010 07:42 PM
What #2 said!
If I’m making rustic furniture, I use a draw knife and peel the bark.
-- Doug...
PurpLev
#5 posted 09-10-2010 07:49 PM
veterinarian… now why didn’t I think of THAT!
Thanks for the ideas, and for the confirmation of the drawknife – that’s how I used the clever (not having a drawknife around)
The reason I don’t want to leave it on at the moment, is that I am keeping the sliced lumber in the basement, going through the kitchen, and don’t want any of the bark to start chipping off all over making a mess. or this will be the last time I’ll be working with wood ;)
View swirt's profile
swirt
2662 posts in 2942 days
#6 posted 09-10-2010 08:05 PM
I use a drawknife for stuff in the 8” or less diameter or a barking spud for something bigger. Though really that is just me, a large drawknife could do it all.
For the drawknife, the problem most run into is how to hold the wood.
I use the crotch of an oak tree and some rope
http://www.timberframe-tools.com/techniques/drawshaving-larger-posts/
A more authentic approach is the shaving ladder
http://www.timberframe-tools.com/techniques/shaving-ladder/
This is a great video of a guy peeling a large log with a drawknife.
Here is a simple video of the barking spud
Notice that either of those methods is fast.
THis guy is using a pressure washer and it takes forever.
And this guy give a great explanation of the options in the old tools
Ahh boy now I’ve gone and lost another half-hour of my day on Youtube LOL
View Div's profile
Div
1653 posts in 2910 days
#7 posted 09-10-2010 10:02 PM
If I want to debark a log a use a flat spade. I have an old one with a short blade just for this purpose. Similar in use to the barking spud. This works best if the log is freshly felled. If the log has been down for some time, the bark becomes real hard to remove!
-- Div @ the bottom end of Africa. "A woodworker's sharpest tool should be his mind."
PurpLev
#8 posted 09-10-2010 10:21 PM
Thanks for the vids swirt, and suggestions, the drawknife looks the easiest and much more convenient to use than what I was doing, but the spur also looks like a good option.
Div – I was working with some 10+ y/o logs, and the bark in some areas peels real easy in large pieces, while other spots it was as if it was glued to the log and hard to remove. thanks for the tidbit!
16274 posts in 4188 days
#9 posted 09-10-2010 10:23 PM
Debarking is easy. Airplane or cruise ship are my preferred methods. Coming home and going back to work is the hard part.
PurpLev
#10 posted 09-10-2010 10:32 PM
hmm…. good thing it’s a friday Charlie.
View dbhost's profile
dbhost
5705 posts in 3202 days
#11 posted 09-10-2010 10:35 PM
Very good one Charlie…
I have always debarked with a camping hatchet. Yes I leave some gouges, no biggie…
CampD
#12 posted 09-10-2010 10:51 PM
I bought a couple different drawknifes from antique dealers or flea markets cheap,
I’m always on the look-out for a deal.
-- Doug...
swirt
#13 posted 09-11-2010 04:32 AM
If you are looking to make due with something you might already have, and you don’t plan on doing this a lot. One of the common dandelion pluckers work decently too (this is not mine)
You can hammer the two tines so that they bend down just a little bit and form a concave shape facing the log. The modification doesn’t interfere with it doing its weed popping job. I had one with a longer handle that worked pretty well …. then it disappeared. I think it is hanging out with some of my stray socks some place.
View Sawmillnc's profile
Sawmillnc
150 posts in 3024 days
#14 posted 09-11-2010 04:47 AM
I have used a pressure washer on cedar and poplar but only on the rare occasion. Debarking is done to reduce blade wear from embedded dirt and rocks.
I generally don’t debark as it isn’t cost effective.
-- Kyle Edwards, http://www.sawmillnc.com, Iron Station , NC (near Charlotte)
Sawmillnc
#15 posted 09-11-2010 04:47 AM
BTW.. commercial logging uses a debarker.
