Bar height table gas pipes
Forum topic by flemdog posted 01-29-2017 10:26 PM 451 views 0 times favorited 10 replies Add to Favorites Watch
View flemdog's profile
flemdog
19 posts in 391 days
01-29-2017 10:26 PM
Hey guys I’m doing a 87 inch long 11.5 inch wide cherry table top ( it’s all one piece). I’ve started buying 3/4 inch gas line . My plan is to run floor flange on top and bottom , 6 inch nipple to tee fitting and I’m gonna run a full piece across the back of the table to connect it all together will this be sturdy enough or just I connect it in more places ?
10 replies so far
View ArtMann's profile (online now)
ArtMann
833 posts in 721 days
#1 posted 01-30-2017 01:20 AM
I am having trouble visualizing what you are describing.
View jerryminer's profile
jerryminer
888 posts in 1347 days
#2 posted 01-30-2017 01:36 AM
“Bar height” means +/- 42” ?
At 11 1/2” wide, I think your table will be “tippy”. You may want to add some weight to the bottom to lower the center of gravity.
flemdog
#3 posted 01-30-2017 01:58 AM
I was thinking about adding a 1 by 3 in the shape of a tee at the bottom basically I would have the table top at 41 inches high . 12 inches up at each corner would be a tee pipe then another 12 inches up would be another tee that’s basically for each corner leg . I would run a piece of 6 inch across in both of those places to tie the legs together . The rear legs would have tees running across to tie the back legs in does this make more sense ?
flemdog
#4 posted 01-30-2017 01:58 AM
Something sort of like this
flemdog
#5 posted 01-30-2017 01:59 AM
woodbutcherbynight
3952 posts in 2314 days
#6 posted 01-30-2017 02:20 AM
From the picture it looks like flanges have been used at the floor. If they are screwed to the floor the narrow width at that height is not a problem as the entire table is held in place at the floor. Even so I am guessing it will shake alot if bumped.
flemdog
#7 posted 01-30-2017 02:38 AM
If I used hair pin legs would that help more or is the only way to make not not wobble to add legs and a table apron ?
View EngineerChic's profile
EngineerChic
34 posts in 409 days
#8 posted 01-30-2017 02:47 AM
I made a sofa table like this, and it looks good but it is a little tippy if bumped. My table is about 72” long, 11” wide, and maybe 34”. I have a stretcher that runs along the back, about midway down. Mine is snugged against the couch so it isn’t a problem (no one runs into it, and it isn’t holding liquids often) but you might want to secure the bar table to the wall. Even discreet little angle brackets would help it feel more sturdy.
Also, I used paint on the pipe to make it evenly black and I found simple green was a great degreaser to wash the pipe with before painting. Just suggesting it bc you might have it on hand.
flemdog
#9 posted 01-30-2017 10:40 AM
Thanks for all the info ! I actually started degreasing the pipe last night with simple green and I will definitely be painting it . My table is going behind a couch though so I can’t secure to a wall . I have laminate floor that is over concrete I hate drilling into the floor but do you think that is probably my best way of securing it ? I was going to use hairpin legs , but it still would of been wobbley right?
flemdog
#10 posted 02-02-2017 01:49 PM
Got it done just need to secure it . It is a tad wobbly but I hope once I secure it down it will be fine .
