Loading Logs by hand: Your input
Forum topic by CovenantCreations posted 09-10-2010 02:17 PM 2281 views 0 times favorited 10 replies Add to Favorites Watch
View CovenantCreations's profile
CovenantCreations
127 posts in 3136 days
09-10-2010 02:17 PM
Last time I had to load logs on my trailer we just used a lot of man power and got them up there, but now Im going to be going and cutting down several cedar trees and some maple, and was wondering how you do it? I probably wont have access to a loader or anything, although i am working on that. But if i dont get a loader there, I will need to load these 8 foot logs on the trailer with just me and one other guy. How would you do it?
10 replies so far
View Peter Oxley's profile
Peter Oxley
1426 posts in 4108 days
#1 posted 09-10-2010 02:38 PM
You could mount a winch on the bed of your trailer, or use a manual chain hoist or a couple of come-alongs, and drag/roll the logs up ramps.
-- http://www.peteroxley.com/woodworking -- http://north40studios.etsy.com --
View Daren Nelson's profile
Daren Nelson
767 posts in 4139 days
#2 posted 09-10-2010 02:41 PM
Logs are heavy, mechanical advantage is my advice. Parbuckle… http://lumberjocks.com/mart/blog/7919. Use a truck to pull them over the side of the trailer. Be careful.
View rivergirl's profile
rivergirl
3201 posts in 3072 days
#3 posted 09-10-2010 03:32 PM
A come along might work? It works for pulling dead cows and they are heavy.
-- Homer : "Oh, and how is education supposed to make me feel smarter? Besides, every time I learn something new, it pushes some old stuff out of my brain."
View Gary Glaze's profile
Gary Glaze
10 posts in 3101 days
#4 posted 09-10-2010 03:40 PM
I use two heavy planks as ramps and 2 peaveys ( one for each person). I have loaded some pretty big logs this way. Enjoy.
View Div's profile
Div
1653 posts in 3174 days
#5 posted 09-10-2010 10:16 PM
That is why logs are round. So you can roll them! ;^)
Good luck!
-- Div @ the bottom end of Africa. "A woodworker's sharpest tool should be his mind."
CovenantCreations
#6 posted 09-11-2010 01:04 AM
Daren I like what I see there. I actually found that post after I searched it. I am glad I came across that though as I can see some real advantages to that. Its making me want to go cut some wood now.
TopamaxSurvivor
18422 posts in 3909 days
#7 posted 09-11-2010 01:48 AM
That is a good link above. I was going to say unhook the trailer and pull them on with the vehicle:-) Depending on where I am loading, sometimes I have my tractor with front end loader and sometimes I have to “rough it!” :-((
View Kindlingmaker's profile
Kindlingmaker
2658 posts in 3760 days
#8 posted 09-11-2010 01:58 AM
Rent an engine hoist at your local rental yard, pick up log, back under it, let down…
View Sawmillnc's profile
Sawmillnc
150 posts in 3288 days
#9 posted 09-11-2010 04:43 AM
You can use ramps and parbuckle up onto the bed of the trailer. I have moved huge logs this way. Cedar can be easily manhandled.
-- Kyle Edwards, http://www.sawmillnc.com, Iron Station , NC (near Charlotte)
View crank49's profile
crank49
4032 posts in 3204 days
#10 posted 09-11-2010 10:45 PM
Yes, what Daren and Skeezics said (or showed). I had my place logged about 10 years ago and my logger used a similar setup; even to load a stake side log truck. Had some poplar and beech logs over 30” diameter.
