coating for patio
« back to Coffee Lounge forum
Forum topic by bamabob posted 09-10-2010 01:40 PM 818 views 0 times favorited 6 replies Add to Favorites Watch
View bamabob's profile
bamabob
4 posts in 2901 days
09-10-2010 01:40 PM
Topic tags/keywords: question
I need to coat an outdoor patio. It is concrete which has been coated a few times previously – no problem with the coating but it gets stains on it that will not come out ( leaves, acorns,etc.) – I am thinking of using a Behr 1 part epoxy coating. Will this clean easily when it gets stained ? I assume that if it is suitable for a garage floor that it will but don’t want to do that much work only to find the same condition I have now.
Thanks
View rivergirl's profile
rivergirl
3201 posts in 2923 days
#1 posted 09-10-2010 07:31 PM
You could try using muriatic acid to clean and etch the surface. You can also dye the concrete using a copper sulfate wash and/or other sulfates. It colors the concrete – and then stains don’t show though- they blend in with the dyed concrete.
-- Homer : "Oh, and how is education supposed to make me feel smarter? Besides, every time I learn something new, it pushes some old stuff out of my brain."
View Knothead62's profile
Knothead62
2584 posts in 3045 days
#2 posted 09-11-2010 01:54 AM
Will the coating make the patio slick when wet? On this basis, I never painted or finished outdoor concrete.
bamabob
#3 posted 09-11-2010 05:52 PM
I don’t know but I’m going to try it this weekend. I assume that if it is made for a garage floor it should not be too slippery. The paint guy at Home Depot told me that it should resist stains and clean up easily for the same reason. We shall see !!
Thanks for your input.
rivergirl
#4 posted 09-12-2010 04:22 PM
Concrete paint is very slippery when wet.. I have used it many times. Concrete dye won’t. It looks natural and it dyes the concrete.. it is not paint.
View John Gray's profile
John Gray
2370 posts in 3970 days
#5 posted 09-12-2010 06:02 PM
I’d go with rivergirl’s idea paint is slippery specially when wet.
bamabob
#6 posted 09-13-2010 12:41 AM
This patio has been coated with several things before and is sealed ( never with an epoxy paint) – I don’t believe it will take a stain at this point.
I wonder if there is an effective way to add some grit to it to reduce slipperiness ?
( Since I’m in Alabama maybe I can just add some grits instead of sand !)
Thanks
