Cracked ends
Forum topic by jma_in_ca posted 01-29-2017 02:54 PM 341 views 0 times favorited 2 replies Add to Favorites Watch
View jma_in_ca's profile
6 posts in 420 days
01-29-2017 02:54 PM
Topic tags/keywords: question
I’m working on a project that involves 2 blocks of 3” thick poplar. I was disappointed to discover the end grain severely checked. Is there anything I could have done to minimize this? What sort of fix would you recommend? I can re trim the ends but I would like to minimize material loss.
Thanks in advance for any tips. First post here!
2 replies so far
View splintergroup's profile
1925 posts in 1153 days
#1 posted 01-29-2017 03:01 PM
Those could be drying cracks, not uncommon and probably there before you cut to expose them.
In my experience they probably will not grow further. What are you going to use them for? They can be secured with a spline glued in (running across the width of the end grain you show) if that doesn’t impact your project.
6 posts in 420 days
#2 posted 01-29-2017 04:09 PM
Well a crankshaft from a Ford 460 is going to mount between the blocks of wood and a panel of glass is going over the top to make a coffee table. So the cracks are really just a cosmetic issue. Still, they bug me so I ended up filling them with epoxy.
