| Forum topic by rpmurphy509 | posted 303 days ago | 263 views | 1 time favorited | 9 replies | ![]() |
303 days ago |
Not sure if this is the correct forum or not… Does anyone have any experience using leather inserts Any on-line or printed resource recommendations would of course Thanks! -Ray -- Still learning everything |
303 days ago |
I have seen some good work from: http://lumberjocks.com/jocks/Tangle -- Gary, East TX -- The longest journey begins with a single step. |
303 days ago |
I would think contact cement would be one way to attach leather. -- Maplewood, MN |
303 days ago |
contact cement is what I use. Use special care to bond the center first and take great care to work your way out. bubbles are a bear to get out. -- making sawdust.... |
303 days ago |
Hi there, -- Thos. Angle, Owyhee Design, Oregon |
303 days ago |
Thanks guys. I found the Tandy store on-line, and they have one over in Wichita (about an hour away). I’ll more than likely wait until the weather gets warmer before I take the trip out there. Any tips, tricks or gotcha info would be great. Never done this before and really don’t -- Still learning everything |
302 days ago |
Hi |
302 days ago |
Sorry it took so long to get back you. The customer was a rancher I’m building a saddle for. Anyway, usually the leather on a desk top is not veg tanned ( Oak) which is carving leather. Nor is latigo used because of the wax. Harness or bridle have the same problems. Many old desks have a rolled on gold leaf inlay pattern on the edges. I would suggest you glue the leather to a substrate of MDF because of the density and smoothness. The glue you want is Barge Contact Cement. Be sure to get some thinner for it as well. Cut the piece of leather larger than the MDF and coat both MDF and leather with the glue. Let it sit until it is dry. Lay pieces of waxed paper on the substate and start to lay the leather in the middle. Fold the leather in half with the glue out. Pull it tight and lay it across the MDF on just the center of the board. Start in the middle and press the leather flat across the board. Move the waxed paper a little and press the leather down from the center out. continue until the side is done and do the other side the same way. Slow is best here. Hold the leather up off the board and press it down with out wrinkles. With Barge you can lift and reset if you need to. When you get is all layed use a laminate roller to finish the seal. I would suggest you wrap the leather over the edge of the board. This will take some careful planning at the corners. To trim use an Exacto knife. -- Thos. Angle, Owyhee Design, Oregon |
302 days ago |
Thos. Angle seems to be the leather guy! That was great information! -- making sawdust.... |
302 days ago |
Fantastic information from all, and a special thanks to Thos.Angle! I’m getting excited about this project and may end up heading This will be used in a portable writing desk, similar to the old civil I will of course post the progress on it when it begins (with pictures). Gold leaf and inlays are a definite maybe. Thanks again all! -- Still learning everything |
| Sponsor | Forum | Topics |
| Become a sponsor |
Woodworking Skill Share
1336 |
| Become a sponsor |
1778 |
| Become a sponsor |
123 |
| Become a sponsor |
371 |
| Become a sponsor |
108 |
| Become a sponsor |
Woodworking Trade & Swap
251 |
| Become a sponsor |
Coffee Lounge
1003 |
| Become a sponsor |
LumberJocks.com Site Feedback
284 |
