| Forum topic by Wiley | posted 982 days ago | 1467 views | 0 times favorited | 8 replies | ![]() |
982 days ago |
Topic tags/keywords: cupping thin stock question I do most of my work with 1/4” and thinner wood, which means that it’s not exactly unusual for wood to cup between resawing and actually making the project. It’s not usually too bad, but one particular piece of oak was cupped enough to interfere with cutting the joinery. I’m going away for the weekend, and I thought I’d leave it clamped to a table while I was gone, and hope that it stayed flat when I unclamped it. Once it’s in the piece, it’ll be held in place by other wood and cupping won’t be an issue, I just need it to stay flat long enough to cut some rabbets with my router table. Is clamping like this likely to work, or should I just give up and find a new piece of oak? Is there anything I can do to make it more likely to work? -- "When you lose the power to laugh, you lose the power to think straight" - Inherit the Wind |
8 replies so far
#1 posted 982 days ago |
Wiley, -- Gerry |
#2 posted 982 days ago |
You probably had a humidity change, so I would think put a weight on it would probably be better than clamping it, allowing the wood to move freely to relax and lay flat. When you come back after the weekend, you should see a change and should be flat depending on what your humidity is there. -- I don't make mistakes, I have great learning lessons, Greg |
#3 posted 982 days ago |
I’m not sure how to get the cup out of this particular board. For future reference though, I thickness plane a lot of my 1/4” material beforehand too. I stack these 1/4” material in stacks with several much thicker boards on top of that stack. The higher the stack of thin stock, the more weight I put on top of the stack. So far, with an axception here and there, this has kept my wood from cupping or warping. |
#4 posted 982 days ago |
Thy a search for a product named “Wood-Loc” Creative Woodworks and Crafts had ads for it back a few years ago, If Sheila sees this mabie she can help |
#5 posted 982 days ago |
Probably too much trouble for a small piece but I use an unorthodox method involving Downy and very hot water. -- Gene 'The true soldier fights not because he hates what is in front of him, but because he loves what is behind him.' G. K. Chesterton |
#6 posted 982 days ago |
Clamping or weighing down the wood for awhile may lessen the cup some at least temporarily. I don’t know if it will be flattened enough to work with. We do as William said and weigh down our thin wood and it does a great job at preventing the cupping and warping in the first place. I mentioned it to Sheila but she doesn’t recall hearing about Wood-Loc. -- Scroll saw patterns @ http://www.sheilalandrydesigns.com ... Pens @ http://www.finestylus.com |
#7 posted 982 days ago |
From what I’ve read in a year 2000 publication, Wood-Loc is a PEG like product that displaces moisture in wood. -- Gene 'The true soldier fights not because he hates what is in front of him, but because he loves what is behind him.' G. K. Chesterton |
#8 posted 982 days ago |
you have to cut the cup out or start with a new piece of wood. no matter how you clamp it it will coe back, next option is to flat plane the cup out if you have a jointer. of course do this when the board is at a 1/4 inch thick then after flat planed use a thickness planer and take it down to final thickness. in other words let it stress first then machine it. |
| Forum | Topics |
Woodworking Skill Share
8784 |
Woodturning
219 |
Woodcarving
28 |
Scrollsawing
61 |
Joinery
77 |
Finishing
1522 |
3542 |
15755 |
Hand Tools
2029 |
Jigs & Fixtures
494 |
Wood & Lumber
2833 |
808 |
Focus on the Workspace
900 |
766 |
Woodworking Trade & Swap
2736 |
LumberJocks.com Site Feedback
1547 |
Coffee Lounge
6148 |
