J&R Dodge Sheffield Hand Plane
« back to Hand Tools forum
Forum topic by r33tc0w posted 01-28-2017 03:31 PM 997 views 0 times favorited 14 replies Add to Favorites Watch
View r33tc0w's profile
r33tc0w
168 posts in 681 days
01-28-2017 03:31 PM
I’ve been searching but have only found limited information on this plane. The company appears to have shown up around the mid- to late 1800s: http://www.holzwerken.de/museum/haendler/dodge.phtml – can anyone shed some light on what I have? It measures 25.375” in length, is this considered a jointer plane?
I picked this up at an architectural salvage store here in New Orleans for $25 – the sole appears to be trued up and the parts are all there. I’m an infant to woodworking and I have watched Paul Sellers clean up a plane but the iron is cambered and I want to make sure I do this right. My sharpening tools are limited, sandpaper, block of 1/2” HD PVC, 1000/6000 whetstone – looking on some pointers and anything else I need to pay attention to as I bring some life back into this plane
-- Matthew 13:53-58
14 replies so far
View Tim's profile
Tim
3812 posts in 2158 days
#1 posted 01-28-2017 06:49 PM
Interesting plane. I’ve not seen one that length with an iron cambered that much.
That’s in really nice shape, I think I would just clean it and flatten the back of the iron and sharpen it. Maybe evaporust or electrolysis to remove all the rust from the iron.
View JRsgarage's profile
JRsgarage
306 posts in 706 days
#2 posted 01-28-2017 07:12 PM
looks like a jointer with a scrub plane blade. LN has a good vid on sharpening a scrub blade
-- Two is One, One is None
r33tc0w
#3 posted 01-28-2017 10:16 PM
So in what circumstances would I use this setup, bringing widths of boards down? I understand it can hog off a lot of material so would I avoid using this to level out the height of a board due to the radius of the iron?
-- Matthew 13:53-58
JRsgarage
#4 posted 01-28-2017 10:41 PM
usually used to for rough stock. it’ll remove alot of material rather quickly off high spots, twists..etc. i find scrub planes work best taking cross cuts. mouth looks a little small but hard to tell from pics. try it out
View TheFridge's profile
TheFridge
10696 posts in 1683 days
#5 posted 01-28-2017 11:41 PM
Typically you won’t see something jointer length with a cambered iron but obviously they’re out there. I have an Alex mathiesson & sons 24” jointer with a barely cambered iron if you’re interest and are ever in the Gonzales area. It’s just sitting on the shelf right now gathering dust.
r33tc0w
#6 posted 01-29-2017 12:33 AM
That’s a mighty offer Fridge, I might have to fancy a short trip if you’re willing to give it a new home :)
fun fact of the day; The Sheffield reference in their logo is for the city in England and apparently they discovered Stainless Steel there, as well as developing an enhanced method of the crucible steel process:
https://en.wikipedia.org/wiki/History_of_Sheffield
Here’s another stamp I missed on the toe:
-- Matthew 13:53-58
TheFridge
#7 posted 01-29-2017 01:02 AM
The stamp on the toe may be an owners stamp?
You’re more than welcome to it free of charge. It’s a hoss. It was replaced with a #7 recently and I didn’t use it much before then.
TheFridge
#8 posted 01-29-2017 01:03 AM
Just shoot me a pm and we can work the timing out.
View OSU55's profile
OSU55
1955 posts in 2186 days
#9 posted 01-29-2017 02:26 PM
At 25” long, it typically would be used as a jointer/panel flattening plane. and would have a straight to slightly cambered iron. If you just want to restore, sharpen up the heavy camber. If you want to use it, regrind the edge straight and hone a slight camber to the edge. With having a chip breaker it would make a good user. Here's some info you might find useful.
View bandit571's profile
bandit571
21729 posts in 2880 days
#10 posted 01-29-2017 02:58 PM
Maybe a cooper’s jointer, cambered for the inside of the Oak staves? Wedge is shaped to curl the shavings….
r33tc0w
#11 posted 01-31-2017 04:35 AM
Cool, thanks for the info guys!
-- Matthew 13:53-58
r33tc0w
#12 posted 03-16-2017 04:46 PM
How do I go about sharpening the camber on this iron? Here’s a cleaned up pic of the iron:
Looks like two pieces of metal almost?
-- Matthew 13:53-58
View Ocelot's profile
Ocelot
2113 posts in 2835 days
#13 posted 03-16-2017 07:33 PM
That iron really looks nice cleaned up!
View HokieKen's profile (online now)
HokieKen
7005 posts in 1335 days
#14 posted 03-16-2017 07:38 PM
You’ll need a honing guide with pivot point that will allow you to follow the camber of the blade. If you use a guide of course… If you’re a free-hander, well… you just do it ;-) Warning though, it can be an exercise in frustration.
-- Kenny, SW VA, Go Hokies!!!
