How to repeat a 30° miter cut on a chop saw
« back to Coffee Lounge forum
Forum topic by EdsCustomWoodCrafts posted 01-27-2017 03:56 PM 389 views 0 times favorited 1 reply Add to Favorites Watch
View EdsCustomWoodCrafts's profile (online now)
EdsCustomWoodCrafts
791 posts in 1394 days
01-27-2017 03:56 PM
So this might sound like a question I should now the answer to as I have been woodworking for a little while BUT
I am making Hexagonal units and it’s one thing to dial in the 30° miter angle on the chop saw, with that accomplished I need to have all piece the exact same length I usually place a stop on my fence but I’m not getting the results I need for tight mothers
To be very specific I’m cutting 30° On 2×4 stock to achieve the angles needed I have to turn the board over as my miter saw is not s double bevel saw..
I thought about using a piece of stock with the 30° bevel cut into it as a stop but that is only good for one of the 2 cuts needed as I need to turn the board over face for face..
Any ideas
-- Thanks Ed “A bad day woodworking is better than a good day working. ~Author unknown”
1 reply so far
View papadan's profile
papadan
3584 posts in 3419 days
#1 posted 01-27-2017 04:38 PM
Hi Ed, sounds like you just need to fine tune your angle. Repeat cuts should be a given after that.
