Question about spline miters for picture frames
Forum topic by Camper posted 09-08-2010 03:50 AM 2703 views 0 times favorited 7 replies Add to Favorites Watch
View Camper's profile
Camper
232 posts in 2857 days
09-08-2010 03:50 AM
Topic tags/keywords: question tablesaw joining
When making miter joints with splines for a picture frame, after squaring the stock and cutting to appropriate lengths, which order is best to 1) cut the L shapes 2) cut the miters 3) cut the spline slots?
Also the spline jig I am looking at making requires that the mitered corner rides on the table saw at a 45 degree. So do I glue the mitered joints and then after I cut the spline slots, glue the spline in?
I am slightly uncertain as to what the best sequence is..thanks for looking and thanks for your suggestions in advance…by the way I am using a table saw for all this.
-- Tampa-FL
7 replies so far
View lew's profile
lew
12062 posts in 3756 days
#1 posted 09-08-2010 04:03 AM
I usually make/assemble the frame and then cut the spline slots. Glue in the splines and trim then sand and finish.
Not sure if this is the “correct” way but it works for me.
Camper
#2 posted 09-08-2010 02:52 PM
thanks lev, also what do you do about the “V” groove left by the combination blade on the saw? It seems like the slot would be to thin to use a chisel to trim.
-- Tampa-FL
View FaTToaD's profile
FaTToaD
394 posts in 3142 days
#3 posted 09-08-2010 05:29 PM
I currently use a combination blade to cut miter splines because it’s the only blade I have. It does leave a small “V” groove, which I’ve tried to knock down with a very small file. If you’ve got a file that’s small enough to get in the groove, you could go that route. Lately, I’ve just left it alone and it’s not that noticeble, especially if you push the spline in with plent of force.
BTW, I saw a 10” blade at Lowes the other day that was ATB+F, can remember the brand, but it was around $30. I’m thinking of buying one just for splines.
-- David
View Lee Barker's profile
Lee Barker
2170 posts in 2851 days
#4 posted 09-08-2010 07:28 PM
The “dab o’glue then sand at 150 grit” trick works good on those little voids. To see an unfilled void, you’d have to smash the side of your face against the wall and close your outboard eye. It’s a minor concern.
I don’t know what you mean by “cut the L shapes.”
I usually cut the miters, glue and clamp with a band clamp (Jorgenson 1”). You can get enough glue strength at that angle for the four pieces to hold together. Then I cut the slots with the frame vertical in my table saw jig.
View TominTexas's profile
TominTexas
42 posts in 2837 days
#5 posted 09-08-2010 07:47 PM
Most of the combination blades as well as cross cut blades for your tablesaw have a small contour to the top of each tooth – that shape helps in the efficiency of cutting but also leaves a v or curved shape to the bottom of the saw kerf. Blades that are designated as “flat tooth” (most are rip blades) leave a flat bottom on the kerf and are ideal for cutting the slot to accommodate the spline. Freud makes several blades with flat teeth that are economically priced.
Tom
-- East Side of Big D
View Dez's profile
Dez
1166 posts in 4078 days
#6 posted 09-08-2010 08:57 PM
All good advice, try using a rip blade for cutting the slots – they usually have a flat bottom cut!
-- Folly ever comes cloaked in opportunity!
Lee Barker
#7 posted 09-08-2010 09:05 PM
Try the rip blade on scrap to see how it exits. A chipout on the back side of your well-wrought frame is more problematic than the little teensy triangles left by a blade that is better behaved when it leaves the work.
