Dewalt Planer, DW735 problems
Forum topic by DaveLikeGolf posted 304 days ago 367 views 0 times favorited 10 replies Add to Favorites
View DaveLikeGolf's profile
DaveLikeGolf
25 posts in 348 days
304 days ago
Topic tags/keywords: planer question
I’ve had this planer for 4 months now and have planed approximately 150bf of wood – mahogany, cherry and poplar. Seems to work well, other than the snipe (which is another story I won’t go into now).
Anyway, during my last couple of planing attempts using mahogany, the boards have been sticking at random locations, requiring me to give it a little shove to start the motion through the planer again. When it comes out on the other side, there is a black mark and little scrapings of rubber, like the rollers were burning out on the wood! Also, I was only taking off 1/16” or less at a time; I’ve never gone lower than that.
I took the top off and blew out any dust and debris. I then cranked it all the way up and cleaned off the rollers, (no solvent, just clean cloth. They were fine). I made sure the blades were sharp and there was no gum or buildup anywhere in the machine or stainless steel plate the wood rides on, it looked brand new. My infeed and outfeed tables (shop built from laminated MDF) are perfectly level and slick as a dolphins back. So after all this, I started it up again and after a couple boards, whadayaknow, stuck again.
Now, it doesn’t do this every time, and it seems like it only does it when the surface the rollers are grabbing has been planed and is nice and flat, like it doesn’t get a good grip. This is my first planer and I’m not sure if this is typical behavior, but it doesn’t seem right. Anyone know what may be occurring?
-- David, Lakeland, FL - GO BOLTS!!!
View Thos. Angle's profile (online now)
Thos. Angle
3409 posts in 490 days
304 days ago
David, Clean the rollers with De-natured alcohol, wax the floor of the planer and put in new blades or reverse the old ones. This is what I do to my 735 when this starts to happen. Also it helps to plane with the grain. I plane both sides of a board and turn it over every time. I never take off more than 1/2 turn on the handle(1/32). I hardly ever get more than about 150 BF before the blades need to be turned. I’ve began to buy my lumber S2SSE at 13/16 then take it down to 3/4 with two passes through the 735. I think I actually make money this way. The 735 is a great planer but it won’t hog massive amounts of wood at a time. It does leave the best surface that can be had. By the way, the black marks sand right out.
View Peter O's profile
Peter O
669 posts in 403 days
304 days ago
Yeah, what Thos. said. Even if the rollers look pretty clean, they can get fine dust pressed into the rubber and then they don’t grab as well. The bed needs to be waxed periodically, and dull knives create a lot more resistance.
Buying stock closer to your final thickness does reduce shop time and tool wear, however I’ve found that the mill doesn’t care whether it’s flat, and at 13/16, you don’t have much material left to get it flat. I have to laugh at material that is “surfaced and straight-lined” ... someone has quite an imagination calling that a striaght line!
-- Coffee is best with a fine layer of sawdust on top. -- http://www.north40custom.com
View mot's profile
mot
4851 posts in 565 days
304 days ago
When my 735 get to the point where I need to put a foot against the bench and pull the board through like I’m delivering a baby, it’s time to clean the rollers and flip the blades. It’s right around the 150BF mark when this happens.
View Festool4's profile
Festool4
54 posts in 306 days
304 days ago
I have a similar issue with my DW735. I will have to try your suggestions. Thanks
-- Festool4
DaveLikeGolf
303 days ago
Thank you folks for your help. I will do what you suggested this weekend (if my wife doesn’t have a baby first, any day now!)
13166 posts in 929 days
303 days ago
Oh so you are about to find out about Mot’s suggestion. Pulling a baby out.
DaveLikeGolf
303 days ago
haha, I think I may leave that to the doctor, but if she finds she needs help, I’ll be able to show her my resume. “Excuse me doc, but I do have a dirty planer with dull blades. I think that qualifies me to assist you if the need arises. It’s basically the same thing, minus the blood and screaming!”
View IowaWoodcrafter's profile
IowaWoodcrafter
249 posts in 604 days
302 days ago
If you don’t turn the planer off before you clean and wax it you’ll get the blood and screaming. ;)
I had this problem as well. I kept thinking the rollers had broke. It finally dawned on me that the bed was probably gummed up with pitch just like other tools get. Cleaned it off and waxed it and it was just like a brand new planer. So, what everyone else is recommending should fix your issue as well.
-- Owen Johnson - aka IowaWoodcrafter
Thos. Angle
302 days ago
Hey, Peter,
Up at Lumber Products they let me pick through whole units to get the ones I want. pretty flat and pretty straight. If not it must be my fault, huh?
View Kevin's profile
Kevin
282 posts in 486 days
276 days ago
I’m glad I found this thread. I just had the same problem with my Dewalt last night. I’ll have to get everything cleaned up really well and may have to get me some new blades.
-- Kevin, Wichita, Kansas
Bookmark And Share This Page
