Forum topic by Stanley Coker | posted 09-07-2010 09:32 PM | 1859 views | 0 times favorited | 9 replies | ![]() |
Topic tags/keywords: question OK guys, here is a question about raised panel doors. This is the first set of kitchen that I have tackled. The client is wanting them to be made out of maple and there are going to be some rather wide raised panel doors. The widest ones will be 25.5” wide, some 29” tall and some 32.5” tall. Can anyone tell what the limit to be safe on raised panel doors would be. I am planning to use 2” stiles and rails for the doors. I sure don’t want to have a problem with them later. Thanks guys. -- Stanley, North Georgia |
9 replies so far
#1 posted 09-07-2010 10:05 PM |
I personally wouldn’t make them more than 20” wide. I would also make the rails and styles at least 2.5” wide. -- Emmett, from Georgia |
#2 posted 09-07-2010 10:20 PM |
Safety wise… I would use a power feeder for larger shaper bits… I would bet under 2” would be fine -- "Ah, So your not really a newbie, but a I betterbie." |
#3 posted 09-07-2010 10:21 PM |
Emmett- curious- what took an hour and 20 minutes? fine tuning the doors? installing them (hinges and all)? or cutting the rails styles and raised panel? I would think that once you have the cutters setup, it’s a run-them-all through sort of a deal is it not? -- ㊍ When in doubt - There is no doubt - Go the safer route. |
#4 posted 09-07-2010 11:16 PM |
25 1/2” is too wide for a single raised panel. If you put 2 panels in that width you will be OK. We don’t like to make doors over 20” wide. When we do we don’t warranty them. Too much risk, and I’m not willing to take it. By the way, I have a raised panel door shop—we produce about a hundred a day, so in 40 years, I’ve made a few doors. We rarely get one back for warranty. Personally, I think even 20” is pushing it, but often you have no choice because of a lot of reasons. Our stiles are 2 1/4” finished, and our rails for staight designs are 2 7/8”. I think 2” is a bit small—you don’t have a lot of glue joint. |
#5 posted 09-08-2010 04:12 AM |
Purplev -- Emmett, from Georgia |
#6 posted 09-08-2010 04:30 AM |
Hey guys, I too have made many raised panel doors. I can’t say that I have ever made a panel that was over 20 inches wide for a door but I have made them that wide and wider for other “non-door” applications. I am just curious as to what you exact concern is with the wide panel on the door. Is it the warping of the panel or the strength of the rail to stile joint as the weight of the door hangs on it? Thanks in advance for your feedback. |
#7 posted 09-08-2010 04:32 AM |
Thanks Emmett. I have not done any raised panel doors yet – so was curious to get some info on it. -- ㊍ When in doubt - There is no doubt - Go the safer route. |
#8 posted 09-08-2010 04:55 AM |
Solid wood…. Movement….. Find a movement calculator, you have to make room for the rails and the wood to move. Rich -- Duct Tape is the Force! It has a light side and a dark side and it Binds the Universe together! |
#9 posted 09-08-2010 05:05 AM |
Order your doors from Kent. There is not much pride in being able to say you made $1.42 profit on each door, even though you did it yourself. Save that for your own projects where the stakes aren’t as high, ie losing the client’s confidence. I own a few profile sets for my panel doors, don’t think any of them are paid for yet… the big shops are set up to do a kitchen in a couple of days, just order with plenty of lead time. Make your money marking up the cost of the doors and building the casework and details. Jus’ my 3 cents worth (I’ve done it both ways). -- Randy "You are judged as much by the questions you ask as the answers you give..." |
Forum | Topics |
Woodworking Skill Share
12027 |
Woodturning
2105 |
Woodcarving
431 |
Scrollsawing
340 |
Joinery
1370 |
Finishing
4902 |
6691 |
28043 |
CNC Woodworking
211 |
Hand Tools
5404 |
Jigs & Fixtures
1417 |
Wood & Lumber
6230 |
1387 |
Focus on the Workspace
2153 |
1186 |
Woodworking Trade & Swap
4754 |
LumberJocks.com Site Feedback
2200 |
Coffee Lounge
8844 |
