Calculating Required Lumber for Project
Forum topic by RickL posted 01-24-2008 12:49 PM 929 views 0 times favorited 2 replies Add to Favorites Watch
View RickL's profile
RickL
253 posts in 3941 days
01-24-2008 12:49 PM
Topic tags/keywords: question
I have a question that in my mind seems obvious but my brain is locked up. I have a set of plans for another clock and included is a cut list of primary wood and secondary wood parts. Unlike other plans I have followed, there is no total number listed for the approx bd. ft. required. For example a 4/4×5” x 36” = 1.25 bd ft. Do I just keep adding them all up and metally try to “lay those parts out” on a board? I know it sounds simple, maybe that’s what I am struggling with, it is too simple :) Thanks, Rick
-- Rick, Union,KY firstlightwoodworking.blogspot.com
2 replies so far
27250 posts in 3822 days
#1 posted 01-24-2008 02:30 PM
Rick, that will work. But unless you don’t make any mistakes plan on getting extra. I generally allow myself 20 percent. Laying out the parts on a board is an excellent idea.
I struggled with keeping track of part lists and lumber amouts and bought Cutlist. It is available at Cutlistplus.com. It is relatively inexpensive ($30.00 for the basic version) and helped me keep track of parts and inventory. It is designed to efficiently plan cuts from available inventory. I found it especially useful for sheet goods.
Hope this helps.
RickL
#2 posted 01-24-2008 06:47 PM
sb, thank you for the information, I will check that software out. As I think back, it seems I have always had plans that included all of that, Woodsmith, WOOD, etc, so I hadn’t given it much thought. Though I have built projects from “scratch” – for some reason I went blank on this one. Thanks again, Rick
