Dewalt Table Saw DW7480
Forum topic by Tiggu posted 01-26-2017 05:07 PM 1236 views 0 times favorited 6 replies Add to Favorites Watch
View Tiggu's profile
Tiggu
15 posts in 633 days
01-26-2017 05:07 PM
Topic tags/keywords: table saw dewalt customer service question resource pine
About a year and a half ago I bought a new Dewalt table saw ( after reading tons of reviews). It worked really well until about two months ago when the wheel that raised and lowered the blade no longer functioned smoothly until it was finally no longer raising the blade at all. I cleaned (blew out) the saw dust after each use and always attached it to my shop vac for dust collection. I took it to a shop and was told that Dewalt has a three-year limited warranty and would most likely fix it free of charge if no abuse it was found. They just quoted me $199 to repair it. My question is should I have it fixed or invest in a new one? If the latter, what kind of tablesaw (not Dewalt) would you recommend?
View msinc's profile
msinc
531 posts in 651 days
#1 posted 01-27-2017 02:22 AM
We had the same DeWalt saw in the shop at work and it ran flawless. Sorry to hear you are having this problem. Also sorry to hear that DeWalt is not going to stand behind it. After I retired I bought a Bosch table saw and I really like it.
Good luck with which ever one you decide on.
runswithscissors
2843 posts in 2172 days
#2 posted 01-28-2017 05:01 AM
I think he was told that Dewalt would fix it (if there were no signs of abuse). He’s had it 1.5 years out of a 3 year warranty. They definitely should fix it.
MrUnix
6944 posts in 2346 days
#3 posted 01-28-2017 05:12 AM
I don’t mean to sound snarky, but seriously?? If you can get it fixed for free, why would you even consider just going out and buying another saw?
And honestly, you should be able to determine what the problem is yourself, just by looking at it and examining the underpinnings while operating the handle. What you describe is fairly common and 99% of the time is dirt simple to fix. Most of the time, it’s just gunk built up on the gears, and a good clean (with a brush, not just air) and lube is all that is required. Occasionally it may be something like a loose set screw or spring pin that has gone missing, but those are rare. Have you even tried to figure out what it is?
Tiggu
#4 posted 01-29-2017 07:10 PM
Thanks for taking the time to read and comment. I’m not sure what Dewalt considers abuse. Msinc – I bought this saw because of the great reviews, and besides the issue mentioned it’s been working great. I almost feel like I should just pay but am afraid that after a while the same thing will happen again, especially since I always took extra care to clean out the sawdust from underneath.
Brad – if Dewalt had agreed to fix it for free, I wouldn’t have taken the time to post here. Regarding your recommendations, I appreciate them. Before taking the saw to a repair shop, I did use a toothbrush to clean up any visible parts to see if that made a difference. But they were fairly clean already. I was about to open it up and see what the issue was, but my husband reminded me that this would void any warranty, which is why I took it to the shop instead of trying to deal with the problem myself. I guess that backfired.
View PlanBWoodworks's profile
PlanBWoodworks
150 posts in 629 days
#5 posted 05-13-2017 01:09 AM
I am sure that you have resolved your issue by now, but I have had the same issue on a couple of occasions. I cleaned everything, and still couldn’t raise the blade. I finally resorted to the old adage, if it move’s and shouldn’t-duct tape. If it doesn’t move but should-WD 40. Against all logic, that is all that it took to get it working like new. I was shocked. I have had it happen a couple more times and WD 40 resolves it every time. If you have the issue again, give it a shot!
-- Why can’t I ever find my pencil???
PlanBWoodworks
#6 posted 05-13-2017 01:12 AM
