Flattening Stone Idea..
Forum topic by jeth posted 09-07-2010 05:10 AM 1099 views 0 times favorited 4 replies Add to Favorites Watch
View jeth's profile
jeth
262 posts in 3013 days
09-07-2010 05:10 AM
Just perusing the many items I am in need of in my shop and the lack of funds to acquire them.. while looking at sharpening equipment I saw a flattening stone, another $30 us to add to the deficit..
Then I had a thought..
I noticed that these flattening stones (used to flatten off the face of a water stone) are silicone carbide, the only difference I can see between them and the cheap silicone carbide stones available to me here are the diagonal grooves across the face that allow the slurry to escape ensuring a flat surface on the waterstone being tuned. Was thinking it may be quite easy to groove a standard cheap silicone carbide stone that would cost me no more than a couple of dollars here to perform the same function, perhaps using a guide and a hacksaw blade or similar. Anybody tried it, good idea or not? When I actually have some decent water stones, rather than the cheap silicone carbide number being my only sharpening tool, I am going to give it a try.
View JuniorJoiner's profile
JuniorJoiner
488 posts in 3616 days
#1 posted 09-07-2010 05:47 AM
how about a flat plate of glass and a sheet of sandpaper. trues my stones just fine. use a coarse wet/dry paper.
-- Junior -Quality is never an accident-it is the reward for the effort involved.
View jeth's profile
jeth
#2 posted 09-07-2010 04:13 PM
Ok, thanks, that would be simpler still… I was just going on the stated claims that the grooved stone avoids a build up of loose material between the stone being flattened and the stone doing the flattening which could then cause an uneven surface. I guess you haven’t had this problem.. are we to assume that the grooved flattening stone is another gimmick product that serves a non-existent purpose?
View Steven H's profile
Steven H
1117 posts in 3236 days
#3 posted 09-07-2010 05:59 PM
Which flattening stone are you talking about? Not every stone is made the same.
I heard they work fine. But they do not stay flat after a while.
If anyone here does not want to flatten their water stone always, then I suggest you buy CERAMIC water stone.
They cost more, but requires few maintenance.
JuniorJoiner
#4 posted 09-07-2010 06:18 PM
I do my flattening near the sink and rinse fairly often. my problem is the flattening stones don’t stay true. and a dedicated quality flattening plate is expensive. if you want to go that road, shapton does make a good diamond impregnated bronze flattening plate. but it is very expensive.
