Table saw miter slot bolts
Forum topic by DrewM posted 09-07-2010 03:48 AM 6052 views 0 times favorited 8 replies Add to Favorites Watch
View DrewM's profile
DrewM
176 posts in 3177 days
09-07-2010 03:48 AM
I am looking for something like a t-bolt but sized for the miter slots on a table saw. The base needs to be 7/8” wide. The widest t-bolt I have found on woodcraft or rockler websites is 9/16” wide. I need to be able to connect various knobs for hold downs and jigs. Thanks for your help.
-- Drew, Delaware
8 replies so far
16278 posts in 4396 days
#1 posted 09-07-2010 04:04 AM
Here is a source that seems to have them.
Personally, I usually use these for my jigs.
13635 posts in 3519 days
#2 posted 09-07-2010 04:05 AM
how about toilet ‘t’ bolts ?
i don’t know the exact size ,
but they don’t cost much ,
they are 1/4 ” .
View docholladay's profile
docholladay
1287 posts in 3237 days
#3 posted 09-07-2010 04:11 AM
Toilet bolts are available in both 1/4” and 5/16” and in they should turn and wedge just about right in the slot. For my saw, I have to use the items like Charlie refers to because my old saw does not have a t-type slot. Those items simply expand and clamp to the sides of the slot so they will work with any type of 3/4” W X 3/8” D slot. I have even made similar ones from wood. It works pretty well, but you have to use a good hard wood like rosewood or something. Anything soft just crushes the wood and the next time you use it, it won’t grip in the slot.
-- Hey, woodworking ain't brain surgery. Just do something and keep trying till you get it. Doc
View Gene Howe's profile (online now)
Gene Howe
10991 posts in 3606 days
#4 posted 09-07-2010 02:39 PM
Are the slots in the table wide enough to accept a toilet flange bolt?
I use them a lot for jigs but, my table doesn’t have the slots in the edges of the miter gauge slot so, I don’t know if they’d fit.
View Nick52's profile
Nick52
2 posts in 1676 days
#5 posted 07-30-2014 02:28 PM
I used Elevator bolts with wing nuts. ground sides of the bolt flat. works great.
-- Nick
View CharlesA's profile
CharlesA
3342 posts in 1976 days
#6 posted 07-30-2014 03:25 PM
I’m curious what kind of applications would call for a t-bolt in a table slaw miter slot.
View OggieOglethorpe's profile
OggieOglethorpe
1276 posts in 2288 days
#7 posted 07-30-2014 03:36 PM
If you can’t find a bolt for the “tee”...
- Drill and countersink a hole for a 1/4” bolt in the bottom of a strip of wood that fits your slot.
- Cut a thin slot from one end of the strip to the hole
- From the bottom, insert a 1/4” flat head bolt
- Mount your jig to the top and install your choice of washer and nut
The wood strip will expand as the nut is tightened and the bolt head is pulled into the countersunk hole. It can generate a surprising amount of holding power.
Here's a commercial version of the same method.
Nick52
#8 posted 07-30-2014 04:14 PM
i used the Elevator bolts to lock down a featherboard
-- Nick
