Thickness Sander Dust Collection
Forum topic by deucefour posted 09-06-2010 09:53 PM 1256 views 0 times favorited 4 replies Add to Favorites Watch
View deucefour's profile
deucefour
285 posts in 3492 days
09-06-2010 09:53 PM
Topic tags/keywords: question sander sanding
Hello,
I am about to wrap up the construction of my shop build thickness sander (thanks to Blake) and I was wondering, for those of you with thickness sanders, would you prefer to use a shop vac with a filter bag installed or a dust collector?, I have both, my thinking is that the dust is so fine coming from the sander that it would not settle in the main bag of the dust collector but clog up the bag that filters the exhaust. I hope that makes sense. Im just wondering which type of vac to use, i could mount a shop vac under the sander for convienience. I will post pics when I am done and many thanks to Blake and Yorkshire Stewart and the other LJ’s who have made these sanders, looks like it is going to work great.
P.S My dust collector has a 1 micron bag for the exhaust, My shop vac is a standard one with the yellow filter bag.
Robert
View MedicKen's profile
MedicKen
1615 posts in 3700 days
#1 posted 09-06-2010 10:21 PM
I would think the dust colllector would be the way to go. The shop vac is not create enough CFM to effectively collect the dust. Depending on the size of the sanding drum and what grit paper I have read that you will need about 400CFM to collect the dust.
View Gene Howe's profile
Gene Howe
11148 posts in 3666 days
#2 posted 09-07-2010 01:28 AM
+1 on the DC.
View ToddTurner's profile
ToddTurner
144 posts in 3561 days
#3 posted 09-07-2010 03:00 AM
i can tell you now from experience that a shop vac is not enough to pull the dust from a drum sander. You definately need better than 750cfm. My van did a little less than ok. my dust collector pulls 95% of the dust and also allows the paper to live longer since it doesnt fill with dust and burn. Hope this helps a little
todd
deucefour
#4 posted 09-07-2010 03:24 AM
Thanks guys for the response, looks like I better use the dust collector, I will be posting the completed project soon, thanks for your help.
Robert
