Circular Saw Blade for 2-in Butcher Block
Forum topic by seadonkey posted 01-24-2017 09:40 PM 2864 views 0 times favorited 8 replies Add to Favorites Watch
View seadonkey's profile
seadonkey
11 posts in 544 days
01-24-2017 09:40 PM
Hello,
First post, and I’m very new to woodworking, so please be gentle!
I purchased a chunk of 2 inch thick butcher block that I need to trim a few inches from. I’m not sure on wood species, but its a light colored hardwood. I will be using a circular saw (I only have a circular saw and jig saw). I was wondering what tooth count to get for this cut. I was leaning toward 60, but would that be too slow and risk burning the wood?
Thanks in advance for the advice.
-- I mostly make firewood...
8 replies so far
View Carloz's profile
Carloz
1147 posts in 648 days
#1 posted 01-24-2017 10:03 PM
Why do you care about being slow ? Are you going to spit out five butcherblocks per hour and if affects your paycheck ? About burning, you will need to sand down the edges anyway so why bother. It is much more difficult to deal with tearout.
seadonkey
#2 posted 01-24-2017 10:21 PM
I don’t care about production speed, of course. :-) I was just concerned about burning due to the slow cut speed, but that is easier to remedy than tear out
View wuddoc's profile
wuddoc
284 posts in 3774 days
#3 posted 01-24-2017 10:41 PM
Why not cut less than the 2” off on first pass to determine speed and if wood burns with 60 tooth blade.
-- Wuddoc
View bigblockyeti's profile
bigblockyeti
5157 posts in 1777 days
#4 posted 01-24-2017 10:42 PM
What size circular saw will you be using for ththis task?
View JBrow's profile
JBrow
1365 posts in 976 days
#5 posted 01-25-2017 02:34 AM
Seadonkey,
The orientation of the cut dictates the type of saw blade. For example, if the width of the butcher block is trimmed by cutting a little off a long edge (the cut line parallel to wood grain) or the butcher block is an end grain butcher block (regardless of the edge to be trimmed), a rip blade would be a good choice. On the other hand, if this is not an end grain butcher block and the end will be trimmed (the cut will be across the wood grain), a crosscut blade would be my choice. I would expect the best results from a quality rip or cross cut blade that is brand new (that is very sharp) and carbide tipped. For a rip cut, a new 24 tooth rip blade and for a cross cut, a new carbide tipped 60 tooth seem good choices.
I like the idea proposed by wuddoc; make an initial practice cut, leaving an inch or so for the final trimming. The practice cut will give you a feel for the saw and the blade as it cuts through the material. After the practice cut, the final trimming can be performed. The final trimming could be a two cut process, in an effort to reduce any burning of the wood. The first cut would leave the butcher block perhaps 1/8” –3/16” too big and could leave some burn marks on the wood. The final skim cut would be set up to produce the size you are after and would remove very little material and any burn marks. The saw blade should run cooler and reduce burning during the skim cut.
As Carloz mentioned, tear out (fraying along the cut line) may be a problem. Since a circular saw blade enters the cut from the top surface, tear out can occur on the bottom face. Applying some masking tape (not painters tape) all along and centered on the cut line on the bottom surface of the butcher block, ensuring it is firmly in place, can help support the wood fibers during the cut and reduce tear out.
A butcher block that is light in color and bought at a store is likely to be hard maple. This seems to be a popular wood for butcher blocks sold by retailers, probably because it is a very hard (dense) relatively inexpensive wood. But from where I am sitting it is difficult to say for sure what wood you have.
View MT_Stringer's profile
MT_Stringer
3172 posts in 3287 days
#6 posted 01-25-2017 02:45 AM
I have a 7 1/4 inch Diablo 60T blade in my circular saw. It works great
Got it at the big orange box store.
http://www.homedepot.com/p/Diablo-7-1-4-in-x-60-Tooth-Fine-Finish-Saw-Blade-D0760R/100627136
seadonkey
#7 posted 01-25-2017 03:03 AM
Thanks so much for the advice fellas! I went with the two cut advice and a 60 tooth blade and it worked great.
Thanks again! And be prepared for more dumb questions in the future
Carloz
#8 posted 01-25-2017 08:35 PM
- MT_Stringer
From recently the biggest orange store is Amazon, and it also became a box store at least in my city.
