Blum Undermount Runners in Solid Wood Case
Forum topic by farimir posted 09-06-2010 11:10 AM 1085 views 0 times favorited 4 replies Add to Favorites Watch
View farimir's profile
farimir
4 posts in 3697 days
09-06-2010 11:10 AM
Hi
Has anyone mounted Blum undermount drawer runners to a solid wood case? I need some advice on how to attach these to a solid wood case without constricting wood movement. I know one can probably drill out the holes on the Blum runner itself to make it elongated, but I do not want to do that if not absolutely necessary. Any other ideas?
View rhett's profile
rhett
742 posts in 3661 days
#1 posted 09-06-2010 02:51 PM
Attach the slides to a piece of wood that has elongated holes in it. Then attach the piece of wood to the inside of the case through the elongated holes.
-- Doubt kills more dreams than failure.
farimir
#2 posted 09-06-2010 02:58 PM
rhett
Thanks for the suggestion, but wouldn’t that take up a lot of space and make the drawer narrow? I even thought of maybe using a dodo with a sliding piece of wood in it onto which I attach the runner, but all this seems to be too complicated. There must be a simpler solution.
View jussdandy's profile
jussdandy
157 posts in 3201 days
#3 posted 09-06-2010 03:04 PM
I really dont think there would be enough movment to worry about, but if you want to you can use the rear mount brackets, they are slotted , would provide plenty of movement room. me personally do not like rear mount brackets, but they do work.
-- Randy I have the right to remain silent, just not the ability ; )
farimir
#4 posted 09-06-2010 03:10 PM
jussdandy
I will have a look at the rear mounting ones. I also suspect that it might be ok to just screw them to the sides as the screws will allow some movement, but I do not have experience with this so I am not sure.
