Template for setting the bevel angle when sharpening
« back to Woodturning forum
Forum topic by BenDupre posted 01-24-2017 01:13 PM 1045 views 0 times favorited 4 replies Add to Favorites Watch
View BenDupre's profile
587 posts in 421 days
01-24-2017 01:13 PM
I laid out $99 for the sharpening rig from Powertek. But now I am too cheap to buy the raptor angle templates. Does anyone know how to set up this rig for grinding specific angle? If I understood the geometry I could make a template but there is a tool holder that needs to be set as well as the distance from the wheel. My grinder has 8 inch wheels if that matters.
I am trying to grind a bowl gouge and I have already messed up the grind trying to free hand it.
Powertec Jig
Raptor Guides
-- The problem with communication is the illusion that it has occurred. – George Bernard Shaw
View Bill White's profile
Bill White
4878 posts in 3893 days
#1 posted 01-24-2017 01:58 PM
Look at Capt’n Eddie Castelin’s YouTube channel. He has drawings and a vid about a grinding jig that you might like to make for almost nothing. I built one, and use it often.
View Bill7255's profile
425 posts in 2217 days
#2 posted 01-24-2017 02:51 PM
See if you have a local turning club. Members are more than willing to help.
-- Bill R
#3 posted 01-24-2017 03:54 PM
Hey thanks. I have seen his jig. How do you set yours up for the proper angle?
View Wildwood's profile
2267 posts in 2067 days
#4 posted 01-24-2017 04:49 PM
Your system looks like a One Way Wolverine sharpening jig clone. See instructions below!
Really need to know the bevel angle of the tool you have to start with!
I use two school protractors with small bolt & nut in the middle of those protractors to measure before & after sharpening. For just a few bucks at HD can pick up a steel protractor does same thing before and after grinding.
Some folks like these angle checkers.
John Lucas made his own raptor guages.
So how do you set up your sharpening jig? Take a look at these Wolverine instructions. This will give you a great starting point. Never saw a need for raptor gauges, learning curve for me was pretty short following instructions that came with my Wolverine.
-- Bill
