Dewalt 735 planer help
Forum topic by MAS520 posted 01-24-2017 02:31 AM 1088 views 0 times favorited 10 replies Add to Favorites Watch
View MAS520's profile
MAS520
30 posts in 640 days
01-24-2017 02:31 AM
Need an adapter for the chip extractor. Want to use my current 2.5 in. shop vac hose for a collector I’m putting together. Any suggestions.
-- Mark,Oelwein Iowa Cardinal Fan!
10 replies so far
View TungOil's profile
TungOil
1034 posts in 641 days
#1 posted 01-24-2017 02:40 AM
Interestingly, I contacted DeWalt about how to properly collect the chips from the 735. I was having trouble with it overwhelming my 800 CFM dust collector. Tech support told me not to use a dust collector with this unit because you can over speed the built in fan. Instead, they pointed me to some crazy leaf collection thing for the top of a trash can (didn’t work). I ended up buying the Rockler dust separator components (http://www.rockler.com/dust-right-4-dust-separator-components) and mounting them in a plywood disk on top of a trash can. I used an old filter bag from my dust collector on the discharge. works like a champ!
-- The optimist says "the glass is half full". The pessimist says "the glass is half empty". The engineer says "the glass is twice as big as it needs to be"
View Lazyman's profile
Lazyman
2527 posts in 1534 days
#2 posted 01-24-2017 04:37 AM
I made a dust separator from 2 buckets that works very well. There is Thien baffle between the buckets. It willf fill up pretty quickly if you are milling a lot of wood so you have to check it frequently. It will actually capture all of the chips even without the shop vac running but works better when I don’t forget to start the vac. I made this as a prototype almost 3 years ago and it worked so well that I just kept using it.
View pintodeluxe's profile
pintodeluxe
5757 posts in 2959 days
#3 posted 01-24-2017 05:08 AM
A true dust collector will work best. I have used the 735 with a 1 hp single stage collector, and a 2hp cyclone and they both work great. It doesn’t cause problems with the chip ejection fan. I have used mine for years that way.
If you want to get a fitting for your shop vac, many are available. The 735 actually accepts 2-1/2” and 4” hoses. Maybe your shop vac is actually 2-1/4”. Find fittings at Rockler or Amazon.
View Kazooman's profile
Kazooman
1145 posts in 2099 days
#4 posted 01-24-2017 01:19 PM
Interestingly, I contacted DeWalt about how to properly collect the chips from the 735. I was having trouble with it overwhelming my 800 CFM dust collector. Tech support told me not to use a dust collector with this unit because you can over speed the built in fan. Instead, they pointed me to some crazy leaf collection thing for the top of a trash can (didn t work). I ended up buying the Rockler dust separator components (http://www.rockler.com/dust-right-4-dust-separator-components) and mounting them in a plywood disk on top of a trash can. I used an old filter bag from my dust collector on the discharge. works like a champ!
- TungOil
That is interesting. The instruction manual specifically states that the 735 can be used with dust collection systems. It does warn that it should not be used with a shop vac since the volume of chips can overwhelm the vac and clog the hose. I have used my 735 with my dust collctor without any problem.
I wonder why Delta has seemed to change their mind on this.
View JoeinGa's profile
JoeinGa
7739 posts in 2153 days
#5 posted 01-24-2017 02:06 PM
That “crazy leaf collection thing ” you refer to works great for me. Here’s how I learned to NOT use a cardboard box, and if you scroll down you can see what I ended up with.
http://lumberjocks.com/topics/43997
View clin's profile
clin
929 posts in 1142 days
#6 posted 01-24-2017 04:16 PM
I just use a bag filter. The blower in the unit is quite strong. I’m not sure exactly how large the bag is, but it is in the range of 50 gal. It’s 1 micron, so pretty good filtering. Although according to my particle counter, the planer doesn’t make that much fine dust.
I got the bag from Pennstate
https://www.pennstateind.com/store/BC3-1V.html
-- Clin
View bigJohninvegas's profile
bigJohninvegas
490 posts in 1608 days
#7 posted 01-24-2017 06:03 PM
Are you trying to go from 4” to 2.5”? I use the dust right connectors from rockler. Some of my tools have the 2.5 port, and some the 4”. My 4 ” dust collector hose fits everything with those adapters.
Here is a link on amazon for an adapter that reduces 4” to 2.5”
https://www.amazon.com/Woodstock-W1044-4-to-2-1-2-Inch-Reducer/dp/B0000223YJ
-- John
View dschlic1's profile
dschlic1
442 posts in 2116 days
#8 posted 01-24-2017 06:33 PM
I have the same issue. For a temporary fix I duct taped a spare shop vac hose to the standard dust collector adapter that comes with the planer. However I think that a 2” rubber pipe connector
would work.
View Lynden's profile
Lynden
74 posts in 3293 days
#9 posted 01-26-2017 07:47 AM
Spectre Performance has many different types and sizes of couplers and reducers. You might be able to find what you need there.
http://www.spectreperformance.com/cat/air-intake-components?cat=C00000271
View Runner's profile
Runner
73 posts in 919 days
#10 posted 01-26-2017 02:14 PM
My 735 is connected to my shop vac + dust deputy using this adapter:
http://www.rockler.com/dust-right-4-in-to-2-1-4-in-shop-vacuum-tool-port-adapter
The fit is perfect.
-- Kjell - Eau Claire WI
