Finishing question
« back to Woodturning forum
Forum topic by Burbs posted 01-23-2017 11:24 PM 585 views 0 times favorited 6 replies Add to Favorites Watch
View Burbs's profile
Burbs
48 posts in 741 days
01-23-2017 11:24 PM
Been having a great time with the new lathe and have a finishing question. Been experimenting with different finishes from waxes, oils, and a mixture of stuff. I really like the ease and look of ‘O.B.’s Shine Juice’ from Cap’n Eddie Castelin and the fact that I can mix my own for a fraction of what they charge for bottled friction is a huge bonus after what I recently spent on said lathe and accessories.
So I have a ton of spalted maple in the wood pile but it is SOFT. Lots of sharpening and still not always getting all the tear out out. So if I sand with a mixture of BLO and paste wax, the sawdust kinds of fills in that tearout and I could just leave it as it looks pretty good, but is their a problem using ‘O.B.’s Shine Juice’ or some other friction polish over that? Not sure if I would have adhesion problems over the wax.
Thanks in advance for any help.
-- ---The day I learn nothing of value will be the day I'm laid to rest--- Burbs
View lew's profile
lew
12156 posts in 3812 days
#1 posted 01-24-2017 12:03 AM
I usually soak the soft/punky spalted wood with thin CA before turning. Then turn as usual. Also, you can sand and leave the sawdust in the voids and saturate those areas with CA. The CA shouldn’t affect Capt. Eddie’s finish.
View Wildwood's profile
Wildwood
2343 posts in 2192 days
#2 posted 01-24-2017 04:15 PM
JMHO, have turned a lot of spalted wood over the years and learned not all of it is worth turning. Learned about using CA glue as a hardener from reading a Russ Fairfield article. Used his procedure of apply turn re-apply turn until finish turning on a few pens. Back then CA was the final finish for pens.
Spalted wood can reach a point in it’s decay cycle its not worth turning for me not going to waste my time. If do more damage every time a sharp tool touches it, time to toss.
My experience with commercial shellac based products is sheen fade back over time whether handled a lot or not. So would not be a big fan of shine juice. I used Hut’s Crystal Coat finish, and it does deteriorate with age.
French polish formulas vary with the finisher some simply use shellac & alcohol others add oil (BLO, olive, mineral oil) the amount of shellac flake to achieve certain cut also varies. Most claim its all about their technique of application!
Russ Fairfield use to describe the same 1/3,1/3,1/3 formula to make his homebrew using varnish or poly. Same thing as shine juice substituting chemical resins versus shellac resin. Flexner’s book & articles when into same formula.
While friction finishes oil varnish (resin) blends whether shellac, poly, or varnish based are fast any easy you are not getting build up of resin the more coats you apply. Whether commercial or homemade talking about a penetrating finish by definition. Yes, poly, shellac, and varnish are film forming finishes, but addition of oil and solvent/thinner hinder film to build up no matter how many coats you apply.
Yes these commercial & homemade finishes have a place in your finishing tool box depending upon use of the turned item and your personal preference.
-- Bill
View LeeMills's profile
LeeMills
564 posts in 1358 days
#3 posted 01-24-2017 04:36 PM
I agree with Bill that sometimes soft is just too soft.
Instead of CA with soft wood I use thinned shellac (2 parts DNA to 1 part shellac) so that it can penetrate better.
Dries quickly but you may need to reapply every 1/16” of final turning. I don’t think I could afford CA for a medium/large bowl.
I can’t say whether finishes may work over wax.
View TheDane's profile
TheDane
5463 posts in 3720 days
#4 posted 01-24-2017 10:36 PM
In the words of the great John Jordan … “Life’s too short to turn crappy wood.”
View Leo Van Der Loo's profile
Leo Van Der Loo
45 posts in 815 days
#5 posted 01-25-2017 12:01 AM
To the question of a finish over wax, that will simply not work.
Something that does not become a solid that adheres to the wood is not a base to add anything to.
-- Have fun and take care
Burbs
#6 posted 01-25-2017 02:57 AM
Thanks for the responses guys. I turned the bowl down and left it thick because the moisture content was still around 20%. I sanded with blo mixed with paste wax and put Capt Eddies on the top as an experiment. Put it in a sack and put it on the shelf. I’ll pull it out in a few months and see how bad it warped/cracked and what the finish looks like. Either way, I’ll finish turning it and see how it comes out.
